DS650 WORTH $8000+?
Old Mar 22, 2000 | 01:49 AM
  #21
desertds's Avatar
TrailMix I have a second production run DS and they just put a foam wrap around a paper filter, oh well I ride mostly sand and will go with a K&N most likely anyway
Old Mar 22, 2000 | 01:55 AM
  #22
desertds's Avatar
Bigdaddy what ever happened with your CT pipe? It has been killing me not knowing how it runs, I will probably go with a big gun but would really like to get the skinny on CT they are one of the best 250r builders there is in my opinion
Old Mar 22, 2000 | 01:57 PM
  #23
bigdaddy's Avatar
The CT pipe gave it a lot of bottom end, but it rev'ed out too fast, and kept hitting the rev. limiter. I adjusted the # of discs to suite my riding style but there was not much top end I'm not sold on the cv carb, so I have ordered the Ron Woods stage one kit, and Pingry's trick airbox. I like having an adjustable pipe, but i think that the new carb,and rev. box should do the trick.
Old Mar 22, 2000 | 02:03 PM
  #24
bigdaddy's Avatar
A honda 250r K&N will work on theDS650. all you need is a 1 1/2" section of 4" dia. emt conduit to adapt the filter to the box. easy!!!
Old Mar 23, 2000 | 12:19 AM
  #25
BlackHawk's Avatar
Speaking of Air filters... If you want, the most likely BEST Air filtration possible check this out: Get a K&N for your DS. (I dunno if the DS650's production K&N filter is close enough in size to the TRX250R's for this trick or not, but if it is, I'd just use that.) Anyhow, Uni sells a FOAM outerwear for the TRX250R K&N Filter. With this setup, you can't get better filtration.
Leave the Uni outerwear dry if you want less maintenance, or oil the uni (maybe just on the inside an option?) for even more dirt stopping power. The long standing question of K&N or Uni filter has been answered - BOTH! All thanks to Uni Filter Corp. So be sure to buy a couple of spares, it's always good to have two filters, and the Air filter companies will thank you also.
Old Mar 26, 2000 | 11:52 PM
  #26
ScoobyDFW's Avatar
bigdaddy, if you aren't getting more top end, with your CT pipe, you may need to re-jet your carb.
Old Mar 27, 2000 | 04:17 PM
  #27
CRTLeech's Avatar
You don't really need new exhaust and a steering stabalizer. You will get used to the "twitchy" steering in a short time. As far as the exhaust goes, just make sure your carb is jetted right. I will probably be picking up a Dial-A-Jet, so I won't have to worry about that anymore.
The tires work just fine for what they are meant for, dirt. If you want to hit the dunes, then any ATV will do better with paddle tires, at least if it has the power to pull them. Some of the smaller ATV's can't pull paddle tires, but the DS won't have any problems (obviously!). The stock tires will work in the sand, but paddles will work better.
Old Mar 27, 2000 | 04:50 PM
  #28
ScoobyDFW's Avatar
CRTLeech, What is a Dial-A-Jet?
Old Mar 27, 2000 | 06:31 PM
  #29
ScoobyDFW's Avatar
bigdaddy, What is Pingry's trick airbox?
Old Mar 28, 2000 | 12:31 PM
  #30
CRTLeech's Avatar
It's a device that uses vacuum and air pressure to automatically adjust the air-fuel mixture, so you don't need to re-jet your carbs.
General information:
http://www.dial-a-jet.com/
ATV's:
http://www.thunderproducts.com/
I have not tried this system yet, but I know it's been around for quite a while and have heard good reports from other forums for street bikes.
