What are you pepz runnin for tires and rims
I'm sure you're aware of how bad the stock dominators suck. Anything else on the planet is better than those, and what you get will depend on where you ride. I use the Ohtsu radials, because I ride mainly really loose terrain and there is no better traction out of any MX style tire, but they don't have good puncture resistance and cut easy on rocks if you're not careful. In my opinion, the best of both worlds is the Holeshot XCT. Ohtsus will give better traction in sandy terrain, but not a whole lot more, and the Holeshots XCT are really durable.
Stock rims suck too - they are .190 Douglas, intead of a rolled edge like every Jap bike has, so they suck and dent very easy. You can have rings welded in them for reinforcement like the Baja wheels, or buy wheels with rings in them already. the carbon fiber wheels narrow the rear width due to diferent offset, and there are mixed feelings around here about there durability.
Ok one more question. I bought sur traks, and I got a hole in one of them, so I used tire plugs and they still slowly leak, so I put some fix a flat in there and it work for a while but then later that day the plugs fell out. I think because the fix a flat.
Does any one know how to plug the tire better? thanks
I've ran SurTraks - very aggresive tire! Believe it or not, I used to run them on my 350X! Nothing they couldn't conquer...
Anyway, I've plugged many tires and they've all held up well, but the holes I'm plugging are just little ones - like from Locust tree thorns, nails, etc. I've got a Titan on my Arctic Cat that has three different plugs, and never loses a pound of air. Never used fix-a-flat or the like, never wanted to screw with the mess in the future when changing tires...
If the hole is too big to plug, remove the tire from the rim and have it patched from the inside with the hot-patch/melt method. A tire place down the road here charges $10 to dismount, patch, and remount.
if you are going to ride in mud get some Pure Sports Realtors for the rear. I have them on the stock DS rim and they are absolutly amazing and you can still spin them almost anywhere with all the torque the DS has!
I run maxis razor up front , 22' Shredders on the Rear for the trails -(2.5 psi) -when i want traction (4psi)when i want wheelspin . (Shaved 7 seconds of a Run with the lower pressure ) !!
In the sand I run Raptor Radials on ITP rims . I like the traction better than the Ohitsu .
prokiwi.
prokiwi.
