Carb bowl screws SUCK!
Old Jul 11, 2002 | 03:07 PM
mxzxracin's Avatar
Hey does anyone know of better screws for the carb bowl?
Mine are striped to hell and back!
Thanks
Nick
Old Jul 11, 2002 | 03:13 PM
reignman78's Avatar
I replaced all the screws on the carb with allen head screws.
warrior007's Avatar
get Stainless steel allen cap screws. alot of people replace em right off the bat.
Old Jul 11, 2002 | 03:17 PM
mxzxracin's Avatar
Do you guys know what size the screw is??
And right now my old ones are stuck, the screws are striped and i dont have a small enough vise grips to grab on to them.. any more suggestion would help.
Old Jul 11, 2002 | 03:21 PM
ThePunisher's Avatar
Hey DSaholic has about a billion of them! Give him a PM and maybe he would send you some. I forgot to grab some frome him at Little Sahara so if you talk to him ask him to give me a PM also will ya.? Thanks .
Old Jul 11, 2002 | 03:27 PM
warrior007's Avatar
If you cant get a vice grip on them, use a drill bit that is just wider than the screws threads, The head will come off the screw once you drill, then remove the other screws and the bowl, the rest of the stripped screw should be exposed and come out with your fingers since there is no pressure on it.
Old Jul 11, 2002 | 03:35 PM
razormazer's Avatar
If you have a Dremel, you can grind a small slot in one side of the head and sort of "unscrew it" with it a slotted screwdriver. be careful tho, sparks and metal shavings will go everywhere so wear eye protection and cover up that carb if you have to take it off to get the screws off!!
Old Jul 11, 2002 | 03:36 PM
DSaholic's Avatar
I hay 100 of each of the needed size 5mm x 10 and 5mm x 12 so if you want some just pm me your address and I will send them off next week.
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 20, 2015 12:36 PM
ghost civic
Jul 19, 2015 10:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
