CT Radiator Shrouds & Baja Lights
I'm asking if anyone has installed the CT Radiator Shrouds on their Baja Edition DS650?
I have a 2000 DS and am getting ready to install the Baja's light kit. I want to know if the shrouds bolt right up or you have to modify them.
CT says they should fit and if not they will refund my $$.
I'm just trying to avoid the hassle of sending them back if they don't fit.
Also, has anyone installed the Baja lights on their older DS? Any problems with the install I should be aware of?
Thanks
Thanks
AZDUNNER,
Yes they will fit. Don't use the top brackets that come with the shroud.
Just bolt them on the aluminum cover for the lights. I use a small rubber washer in between.
Click here for a photo.....Ct Radiator Shrouds on my Baja
I havent put the radiator shrouds on yet but plan on it. As for the baja lights I've been looking around and haven't found anybody that make a light kit for the big lights. the ones you see in the pictures were custom made I know because i called the guy that made them. I'm setting my ds up for desert racing but I'll have to have someone make some brackets and powder coat them.
northjeepster
northjeepster
northjeepster have you tried contacting ricky stator?
www.rickystator.com. he provides many of teh top dessert raceers with their lighting systems
Steeldon
09-09-2015 09:38 AM
Logan Collins
09-05-2015 08:03 PM
