Steering instability
Old Aug 10, 2002 | 06:43 PM
BlueRap's Avatar
I have 2001 DS. Is there any way to fix the unstable steering feeling that I get when going down a steep hill with out changing the stock upper A-arms?
[img]i/expressions/face-icon-small-sad.gif[/img]
Old Aug 10, 2002 | 07:08 PM
Eaglecollector's Avatar
Make sure that your toe (out) is correct. It should be between 1/8 and 1/2 inch toed out. That will make all the diff in the world.
Old Aug 11, 2002 | 02:24 AM
Hightower's Avatar
Set front shock sag first, for your weight, 'cause toe changes throughout suspension travel. Ideally, I've found that the best steering handling comes from 2 to 2-1/2 inches of sag on the front shocks, and 1/8" toe-out which must be measured with you on the bike in normal riding position. Add to that new tires, and throw the dominators in the trash. Some guys like a little more toe-out, like eaglecollector, but any amount of toe-in sucks big time.
Old Aug 11, 2002 | 12:05 PM
mxzxracin's Avatar
I got a question for you hightower.
If i buy new front tires should i also buy new rims, are douglas rims off set like the new rims on the baja? Is it worth the Extra $$$$ to buy off set rims?
Thanks
Nick
Old Aug 11, 2002 | 02:54 PM
Hightower's Avatar
I've been told that the new Baja rim offset, which makes the front a little narrower, helps improve handling too, but I haven't had the chance to ride a Baja to find out, and even if I did I wouldn't be able to tweek the suspension and toe for my weight just for a quick spin, so I really couldn't compare.
The magazine articles rave about how much better the Baja handles, but how much of that is due to the tires/rims/a-arms remains in debate.
I'm not sure what offsets Douglass offers, I haven't looked into it. I know they offer a variety of offsets for the hondas, maybe they do for the DS too.
I know that the tires alone will make a good difference, they did for me, and if the rims make it even better and the loss of width doesn't bother you, then get 'em.
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
