specialist of nos
Old Aug 24, 2002 | 07:15 PM
bombds650's Avatar
i have a ds650 2000,ron wood sold me a nos system #03100-03105.i install the kit like onwer's manuel p/n a5058-snos,page 16,figure 9.
i put the key at on and i armed the system the pump gaz work and the selenoid actived when i push the bottom.
when i start the atv and i armed the system at 6000 rpm i has back fire and when i push the bottom the fire cut off,
if i don't armed the system i shift at 10,000 rpm and i don't have the problem.
somebody help me
tks
peter
Old Aug 24, 2002 | 08:01 PM
Majorecho's Avatar
Peter- have you tried pulling the lines off the foggernozzle and purging the system into the air? you should be able to verify that both the nitrous soleniod and the fuel pump soleniod are working together. You may have a bit of debris in one of the lines or jets and
you can harm your engine if they are not working in harmony.
Go to the following link and get the NOS tech support number and call them Monday befor you nuke your engine.
NOS INFO
RhinoOffRoad
Jun 11, 2013 10:45 PM
Hez
Oct 18, 2004 03:09 PM
badazzpred
May 26, 2004 01:22 AM
Corpsie
Aug 13, 2002 06:37 PM
Corpsie
Aug 8, 2002 08:36 PM
