RWR Baja Ignition
Old Sep 3, 2002 | 06:58 PM
Sandaholic's Avatar
I have the opportunity to buy a used RWR Ignition box that's for a 2001 DS650. What will need to be done to make it work on a 2002 Baja? I heard something about the connectors are different. Anyone have a RWR ignition fail? Does RWR warranty there product?
Old Sep 3, 2002 | 07:44 PM
Shadow11m's Avatar
the wire set up is different.
Mine came with instructions to unform which wire went where.
All it requires is simple snip and attach ... the only problem is that the space is limited.
On a scale of 1-10 I would rate this a 1.5, not hard at all.
I'm sure they will fax you a wire match up or email you one. Just tell them that you bought it and lost the wire match ups.
Old Sep 3, 2002 | 07:48 PM
JMAC650's Avatar
You do have to cut the connector off and connect the wires one by one. I put one on my baja and it works great. Not sure of the wiring order but i'm sure someone on this website knows what it is.
Old Sep 3, 2002 | 08:21 PM
Batoutahell's Avatar
Actually you do not have to cut the wires unless you want to. I put a rwr box on my baja and here is what I did.
I pulled the pin connectors out of both connectors, using the info from woods as to what color wire went with what, I connected each wire.
The pins will slide together, they do not snap or anything, but will slide into each other. Then I took some heat shrink tubing and shrunk it onto each connection, then I wrapped each in electrical tape, and then the whole bunch in electrical tape. Here is the wire code from rwr.
Baja Wood Racing
Red-violet Red
Black-yellow White
Black Black or Blue
White-green Orange
Black Black or Blue
Green not used
remove the connectors from the Baja wiring block and plug them into the new amplifier box as per the color code above.
And by doing this, if I ever had to put the stock box back on, I can just plug the wires back into the connector and plug it into the stock box.
Hope that helps
Bat
Old Sep 3, 2002 | 08:22 PM
That was space out better before, if you need more help let me know.
Bat
Old Sep 4, 2002 | 05:17 PM
Puttnutt's Avatar
Is there a noticable difference in performance with the RWR ignition box, other then the removal of the Rev limiter ? Thx in advance, R
Old Sep 4, 2002 | 07:41 PM
JMAC650's Avatar
My baja seems a little more snappy and pulls harder in the higher rpm's.
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
kbazzy
Sep 26, 2015 11:26 AM
Sw00p
Sep 24, 2015 02:50 PM
