running hot?
Old Sep 8, 2002 | 05:26 PM
lilnotts's Avatar
i noticed my fan has been coming on like all the time, i bought engine ice and tried that, now it doesn't come on after high speeds but it still comes on alot,wat can i do to stop this? i was thinkin maybe ct racing shrouds? am i runnin lean or somethin?
Old Sep 9, 2002 | 01:45 AM
JMAC650's Avatar
Check out Buttfungus's jetting/mods page and see if your jetting is correct for your elevation. There is alot of set ups on that page that might help.
Old Sep 9, 2002 | 02:09 AM
918sTaxi's Avatar
Check your plug. When my bike was running realy hot I was running way rich. I had to come down 2 jets.
Old Sep 9, 2002 | 03:38 AM
BlackHawk's Avatar
Checking your jetting is a good idea, you should do that just because. I have the CT radiator shrouds, and I think they are pretty decent. I added some stick on ruubber stuff to prevent any metal to metal contact. I'd have to have a pair of $65 radiator shrouds wear a hole in a $400-500 radiator. I also added a little bit where the front plastic contacts the shroud as well, since the plastic was wearing a hole into the shroud.
Old Sep 9, 2002 | 09:39 AM
BillDS650's Avatar
The radiator cost me only aout $150.00 from Parker Yamaha
Old Sep 9, 2002 | 09:02 PM
lilnotts's Avatar
well wat color should my plug be?
Old Sep 9, 2002 | 10:10 PM
JMAC650's Avatar
It should be like a golden tan color.
Old Sep 9, 2002 | 10:38 PM
lilnotts's Avatar
well i just went out n checked my plugs, they are darker then golden brown, wat does that mean?
Old Sep 10, 2002 | 02:39 PM
918sTaxi's Avatar
Your running rich.
Old Sep 10, 2002 | 03:06 PM
02BAJA's Avatar
I am having the same problem. I have my fan on a manual switch so I can turn it one when need be. Well, its been hot the last few weeks. so when I get on it and get it warmed up I turn the fan on. With the fan running the whole time I will still get a overheating light after about 45 minutes of riding. Plugs look good! I am out of ideas.
