Web Cams!?
Old Sep 23, 2003 | 09:20 PM
  #21
Hightower's Avatar
Default Web Cams!?
to change the springs you gotta remove the head, so have a head gasket too, and if you know of a good deal on a piston used then get it and some new rings and install it while you're at it- it'll potentially save you another head gasket down the road.
the springs can be gotten directly from Web, cheaper than RW. Web and RW can get you shims, around $5 each, but a local bike dealer may stock the right sizes so its worth checking.
Web Cam DS Page
Old Sep 23, 2003 | 09:28 PM
  #22
DSWOLF's Avatar
Default Web Cams!?
i got parts from ron woods before and i got really great service but i never got anything from web so i can't judge them.maybe i should try them,anyway how many shims do i need??
Old Sep 23, 2003 | 09:36 PM
  #23
DSWOLF's Avatar
Default Web Cams!?
sh*t i forgot to ad something,i'll never be able to get used parts up here,you can't get sh*t for the ds up here it's sad,that's why i'm trying to shop in the state's you guy's can get anything,by the way thanks high.
Old Sep 23, 2003 | 10:32 PM
  #24
ThePunisher's Avatar
Default Web Cams!?
You should make sure to trim the stems of your valves at least .015 before reassembling your head. Make sure you have a machine shop do it. That is if you are running shim under buckets that is.
Old Sep 23, 2003 | 11:14 PM
  #25
DSWOLF's Avatar
Default Web Cams!?
what if i don't run shims under?
punisher please explain,thanks.
Old Sep 24, 2003 | 12:27 AM
  #26
Default Web Cams!?
If you don't run shim unders you will be fine.
Old Sep 24, 2003 | 01:05 PM
  #27
Hightower's Avatar
Default Web Cams!?
also, if you have shims that are too thick and need thinner, you just have a local machine shop grind them on a magnetic base surface grinder. they cna make them whatever thickness you need, for like $10, and no waiting on shipping. have them grind a bit from both sides, rather than all from one side.
Old Sep 24, 2003 | 01:31 PM
  #28
MudStud's Avatar
Default Web Cams!?
I am running .433 lift and dont use the under bucket kit.. Keep your valves in spec and dont reve past 10K and you should be fine. I have the RW valve springs.
Old Sep 24, 2003 | 01:41 PM
  #29
DSWOLF's Avatar
Default Web Cams!?
the one's i will get are 425 lift,287 duration so i should be ok be just replacing the valve springs,shouldn't have to trim the stems or grind the shims,right.
Old Sep 25, 2003 | 07:20 PM
  #30
Hightower's Avatar
Default Web Cams!?
whether you need to grind the stems will depend on the base circle diameter of the new cams compared to the old. If your current valve lash is correct, and the new cams have a base circle exactly the same as the cams removed, then the same shims you have in now will be reused. If the new cams have a larger base circle, thinner shims will be needed, and if the base circle is smaller then larger shims will be needed. I've have found that aftermarket cams do not stick to tight tolerances here. Web and RW tolerance on base circle has a range of .010". Base circle diameter is the diameter of the circle that the lobe is on, not counting the lobe height.
Web will tell you that the spring kit will come with the right shims, but they are clueless in reality to what shim you really need, because they have no way of knowing what everbody's cams measure. no way can every bike out there use the same shims, hence the variety available.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
