Powdercoating frame and swingarm?
Old Sep 12, 2002 | 06:02 PM
JMAC650's Avatar
I am going to powdercoat my frame and swingarm Black and want to know how hard is it to take the DS650 apart? Any special tools or tricks I need to know?
Old Sep 13, 2002 | 10:31 AM
DDrecDS's Avatar
I found it simple to take apart.Make note of the wire and cable routing and what plugs into what.The manule is unclear on some of that stuff.Good luck.
Old Sep 13, 2002 | 01:25 PM
JMAC650's Avatar
I was going to label and take pictures of everything so I make sure it would get put back together right. I was just curious if there was any special tools you need to take the quad apart and put it back together or is it all just basic hand tools.
Old Sep 13, 2002 | 04:03 PM
Knutz's Avatar
To put it back together properly, you should buy or make a tool to hold the first swing arm nut in place as you torque the second nut to it. The first nut should be set to toque, and if you can't hold it while you "sinch" the second one to it, it can tighten up and cause the swing arm pivot to bind.
It's not an absolute neccesity, but it helps do it right.
Old Sep 13, 2002 | 05:05 PM
JMAC650's Avatar
I see what you are saying. Are there any torque specs that I need to know about when putting it back together?
Old Sep 13, 2002 | 07:44 PM
Hightower's Avatar
If you're going that far, spend another $50 for a shop manual from the dealer, then you'll have all the torque specs too. there are many, and they are all important. there's a lot of tricky little stuff everywhere, o-rings and such, and the parts diagrams are invaluable too.
Be aware, some conversions in shop manul are incorrect, I've found a few, and I'm sure there are more I've missed. Just be sure to calculate the metric-inch / foot pounds-newton meters conversions yourself for confirmation before trusting them.
Valder
Nov 28, 2020 07:38 AM
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
