Custom paint on a DS
Old Sep 23, 2002 | 10:02 PM
lilnotts's Avatar
scooter, i painted the "bombardier,rotax,650 & 4valve" on the side of my motor yellow, i just used a small paint brush n quality paint, its kinda a pain but its worth it,
Old Sep 24, 2002 | 01:13 AM
AZDUNNER's Avatar
To paint the engine I use regular engine enamel (spray paint) that you would paint an engine block with. The paint is a high temp. and will not flake off. Spray it in the cap until you get enough to work with.
Use acetone, or another solvent that won't leave a residue, to the clean the area first.
Go to a model/hobby shop and buy a good quality (fine point) paint brush.
Get some thinner while your at it.
One trick is to tilt the DS over on it's right side. It's much easier to flow the paint into the indented BOMBARDIER that way. No need to lay it all the way on it's side. Just use a block (2x4) or something to support the quad while it's leaned over.
Have some Q-tips handy (dip in clean solvent) to remove mistakes.
I had orginally painted the same area w/ yellow and it was next to impossible to remove it. I ended up painting over it w/ the red.
Take your time, use good lighting and you should have no problem.
Old Sep 24, 2002 | 10:44 AM
Bom2000's Avatar
That is deffinatley one really nice DS. The nicest one I have seen to date. If you were to buy like some sort of stensil and buy the right paint do you guys think it would come out the right way or is this a job for the pros.
Old Sep 24, 2002 | 12:02 PM
jeffnrivercity's Avatar
AZDUNNER,
That is way to cool...great job!!
Jeff
Old Sep 24, 2002 | 04:51 PM
  #15
Snakehunter's Avatar
Azdunner
Looks Good.
Keep it right side up.
Old Sep 24, 2002 | 06:35 PM
  #16
JMAC650's Avatar
Looks great. How well does the paint stick to the plastic? I mean if you brush a tree or bend the plastic will it flake off?
Old Sep 24, 2002 | 08:37 PM
  #17
AZDUNNER's Avatar
Adding a plastic adhesion promoter and flex agent to the paint is to prevent this. The plastic currently bends without cracking/chipping the paint however, if I flip the quad in the rocks or drive it into a tree I don't think the paint will survive where it hits.
Time will tell if problems arise through normal use but I don't think they will.
I have not driven it through the brush or trees yet so can't tell if that will cause a problem. it seems pretty tough though.
Old Sep 24, 2002 | 10:20 PM
  #18
sevenac's Avatar
i live in the northwoods so a big factor is how will it stand up to scratches. I would be interested doing a similar design but would need to know if I would end up with a big yellow scratch while riding through the woods
Old Sep 24, 2002 | 10:51 PM
  #19
quadzilla499's Avatar
That is one of the best looking ds's i have ever seen.
Customer Service #1
May 15, 2020 08:46 AM
shimanok2
Jan 29, 2016 07:37 PM
Alex G.
Sep 19, 2015 06:34 PM
carid
Sep 14, 2015 03:40 PM
