Sand Tires?
Old Oct 3, 2002 | 12:14 PM
Mike330R's Avatar
How much air do you have in those tires? If you have them "hard" you will spin all day. Try 3-8 pounds and see what works best for you.
Old Oct 3, 2002 | 03:50 PM
Puttnutt's Avatar
I just picked up the following sand wheels/tires on Ebay, can you tell me if this is a pretty good set-up? thx....Fronts,GBC DUNE TRACKERS 22 X 8.00-10 MOUNTED ON POLISHED ALUMINUM .160 DOUGLAS WHEELS and rears are,KENDA GECKO'S REAR PADDLE TIRES AT21X11-10 MOUNTED ON POLISHED DOUGLAS .190 RIMS thx in advance, Rich A
Old Oct 3, 2002 | 04:54 PM
WyoDuner's Avatar
Puttnut, the fronts are what I have on my Banshee and I like them. Take it easy at first as they tend to catch pretty hard if you're not used to the bite - I nearly high-sided a few times before I got used to them.
The Geckos..... Well, people report mixed results with them. I have seen a lot of them in action and they seem like a good all-around tire but the hook-up is definately less than Haulers. As long as you're not trying to tackle the huge steep hills they will serve you well.
Old Oct 3, 2002 | 05:00 PM
velocityraptor's Avatar
<< BIGds650rider,
Make sure you are not mistaken a slipping clutch for spinning tires. If all you have on your DS is an ALBA pipe and CDI, A 10 paddle haller should be more than enough.
Biggerisbetter.
I 2nd this.
Old Oct 3, 2002 | 05:01 PM
  #15
Puttnutt's Avatar
I just wanted to say thanks for the reply to my post about the sand tire set up I
posted on the forum. I'm not to aggessive out there so a good &quot;all-around&quot; set-up is
what I was after, Take care and thx again, Rich A
Old Oct 3, 2002 | 05:25 PM
  #16
1BigDSRider's Avatar
How can you tell if your clutch is slipping? What should i look for?
Old Oct 3, 2002 | 05:38 PM
  #17
biggerisbetter's Avatar
Well, its actually really wierd. when my clutches slip I can tell my quad is loosing power but I don't hit the rev limiter. WHen your clutches are cool and you go out for the first thirty minutes or so, every shift feels strong and you can hear the engine pull down with every shift. But when the clutches are slipping you don't get the &quot;kick&quot; when you shift, and the engine sounds and feels more like an Automatic.(especailly drag racing)
I recently ordered some HD clutch springs from Ron Woods and &quot;shimmed&quot; them with a couple of washers on each one for added strength. I also change my oil to Valvoline 50w. good luck.
Biggerisbetter.
Old Oct 3, 2002 | 08:19 PM
  #18
JSsDS's Avatar
<< Unless your motor is built 10 paddles is to much. Go with the 8 paddles as suggested. jmo >>
I have 22x11x10-10paddle extremes and I beat everybody with a stock motor/similar mods, at sand mtn. My motor is stock accept for the mods listed below, no internal mods or carb. In other words I have no problem at all. It must be a problem with the Raptor. [img]i/expressions/face-icon-small-wink.gif[/img]
<< i agree it was the 10 paddles that got you not the tire size and the 22 will clear with no problem >>
My 22s ate my heel guards in the first 10 minutes.
AZSand!! Remember, you have an extended swing arm, clearance definatly isn't a problem for you
Your best bet is to trim off the ears that stick out the farthest on your heel guards. The paddles catch them when the suspension compresses and pulls the heel guards down below the pegs [img]i/expressions/face-icon-small-mad.gif[/img]. I just ordered a set of Roll foot pegs and heel guaards to replace the mutilated stockers [img]i/expressions/face-icon-small-happy.gif[/img] I guess it wasn't such a bad thing [img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 3, 2002 | 09:20 PM
  #19
maddog56's Avatar
<< I have 22x11x10-10paddle extremes and I beat everybody with a stock motor/similar mods, at sand mtn. My motor is stock accept for the mods listed below, no internal mods or carb. In other words I have no problem at all. It must be a problem with the Raptor. >>
i have 10inch, 10 paddle extreme haulers on my stock raptor and have noticed a slight loss of power in the bottom of third gear. i plan to drop a tooth on the front, that should take care of my problem.
btw, i still waste all of the stock raptors and many with pipes and other mods at the sand hill climb. thats regardless of thier tires. i just notice that when i shift up from 2nd, they start to gain a little till i get higher up in 3rd.
Old Oct 3, 2002 | 10:44 PM
  #20
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
OPPS I FORGOT JSsDS i can proabably run 26-28's on mine but i still ran my itps on my stock bike too i just cut the angled part of my heel guards off!!!
