I have a?
Old Nov 15, 2002 | 05:48 PM
bombrider's Avatar
Default I have a?
hey thanks, i'l try it. but lets say i buy a k&n filter, will i have to rejet again??
thanks
Old Nov 15, 2002 | 05:54 PM
KenDS's Avatar
Default I have a?
If you do, be sure to get the pre-filter also. And yes. You will probably not need to change your clip but you will be running a 180 or 185 main with 3 turns out on the idle mixture screw.
Old Nov 15, 2002 | 06:00 PM
bombrider's Avatar
Default I have a?
Ok thanks i'l try it tomorow
Old Nov 16, 2002 | 06:53 AM
bombrider's Avatar
Default I have a?
Hey i t still dosent work!!!! [img]i/expressions/face-icon-small-mad.gif[/img]
Could this not be a jeting problem??? maybe electrical????
thanks
Old Nov 16, 2002 | 07:07 AM
  #15
bombrider's Avatar
Default I have a?
Hey, i jast notist something, the stock main jet size is 165, wich is 176 in dynojet size, wich meens that if i went to a 175 main i actually lost some air flow???? whas that all about?????
Old Nov 16, 2002 | 12:54 PM
  #16
jiminok's Avatar
Default I have a?
Hey guys...our Isralie brother is having some major difficulties here! I'm in my last semester as a freshman at DSU thanks to this forum, and my own trials and tribulations...so if you see the need to edit my humble offerings of help please do so...
I pretty much have the same setup as you--except my T-4 is now hanging in my garage and a tuneable Wb E-series is on...I have only a couple of rides on it with the 12 disks it came with but have ordered another doz (and longer bolts) and plan on getting it dialed in to my liking soon...
So your quad was running good before you installed the DJ kit? If yes then I would rule out electrical problems...the kit came with pretty good instructions as well as explaination of fuel circuitry (idle, 1/4 to 3/4 throttle, and WOT), and troubleshooting...you should have access to a carb diagram through this forum...make sure you didn't misplace or misalign any of the seals, springs, or spacers on the carb when reassembling it...and didn't get any sand/dirt inside...
How does your exhaust look at 3/4 to WOT? If it turns black or sooty then your getting too much fuel...if it doesn't then it's too lean...or not getting fuel due to some mechanical settings like the float out of adjustment...float not allowing the bowl to fill up completely resulting in "fuel starvation". Either of these situations and you'd get the poor running problem your experiencing...
I would guess that the air over there is very dry...no? double check your intake boot for cracks...I've heard of people using cigarette smoke to locate a crack (while engine is running hold cigarette close and look for smoke being pulled into any opening around the carb or boots). This may be very bad advice so please be careful if you try it...as bad as using ether and a match to reseat a tire!
...take your time, be patient, be thorough (complete) while checking each part of the carb and fittings...
I can't remeber if you've tried loosening your gas cap while running it--checked the vent hose for a pinch? Also checked fuel tank for trash?
I'm away from my home right now and don't have access to my dynojet instructions so I can't be any more thorough than this...I hope you find the problem soon...good luck and keep us posted!
jim
Old Nov 16, 2002 | 01:14 PM
  #17
bombrider's Avatar
Default I have a?
Thanks man. its winter now so its rather moist. i'l try all those things tomorow.
Actually it did that before we instald the pipe and filter, but only in high rpms, so i guess it maybe hit the rev limit? i donno, you think its conected to the this problem????
Old Nov 16, 2002 | 01:21 PM
  #18
buttfungus's Avatar
Default I have a?
The jet kit and your pipe combo will make you hit the rev limiter more quickly. You could just be hitting the rev limiter,causing your ds to sputter.If you buy an aftermarket cdi it will be much better. Ron Woods,pami,alba, and I think gradon sells one. The Rw and pami have no rev limit and IMO are the best.
Old Nov 16, 2002 | 01:37 PM
  #19
bombrider's Avatar
Default I have a?
Its definetly not the rev limit now, becouse when it starts to sputer, if i stick the gas all the way it clears.
Old Nov 18, 2002 | 01:41 PM
  #20
KenDS's Avatar
Default I have a?
Go to the 185 main jet. No other changes. If it gets better but still sputters a little, go to the 190. If it sputters on top end (not the limiter), go back a main jet size and move the needle clip one slot down.
