Oil return line.
Old Nov 19, 2002 | 09:42 AM
02BAJA's Avatar
Default Oil return line.
Originally posted by: MadBaja819
While we're on the subject what kind of oil pressure should the bomb be running? And does the idiot light come on for oil temp. and pressure or just pressure and water temp? Thanks, Bom2000 and 02BAJA, I will PM you guys the numbers tonight when I get home from werstling practice anyone els that wants them is free to have them just leave a message here.
Thanks MadBaja19. As far as the oil pressure. I have an autometer presure gauge and it will run 25-35 at idle when warm and 50-60 when cracked open. While the oil is cold, it is much higher both idle and WOT.
Old Nov 19, 2002 | 10:20 AM
Bom2000's Avatar
Thanks Madbaja.
Old Nov 19, 2002 | 02:00 PM
MadBaja819's Avatar
Thanks 02 and by the way no problem Bom2000, I'm in school right now, so I don;'t have the numbers with me, but I should have them posted by 8 tonight hopefully.
Old Nov 19, 2002 | 11:05 PM
MadBaja819's Avatar
Alright well here goes, I am getting SSFLEX hose size 5/8 and 4' for 13.99 part number 865-39604
SSFLEX hose 3/8 for 13.99 6' of it for the oil return 865-2940006
Pro Hex Clamps "red" 3/8 pair for 4.99 865-2252B
In-Line Hose fitting adapter two of these to install in the oil return line to hook my gauges. 9.99 a piece 720-2975
Autometer 2 1/16 Electricl gauge "oil temp up to 250*" 35.99 105-2542
2 1/16 Gauge Panel "1 hole" 11.99 two of these. 105-2236
Pro Hex Clamps "red" "5/8" 6.49 for a pair. 865-3252B
Autometer 2 1/16 Electrical Gauge "oil pres up to 100lbs" 47.99. 105-2522
So you know my set up the 3/8 line will be for the return line, the 5/8 for the enter line. The inline adapters will go in the 3/8 line and will allow easy hook up for the gauges. The gauges will be mounted 1 on each side of the dash where the tach is. I have measured everything out perfectly and it will not interfere with anything and will be easily visible. I will plice the power into a set up wires underneath the dash as done with the kill switch. I have not decided yet if I will go with a cooler now or not, but I have come up with a perfect mounting spot and have found the best fitting cooler possible I believe. It is a 4 row power steering cooler the will mount perfectly onto the frame rails to the left of the bottom of the oil tank if you're looking at the quad head on. It is part number 771-1009 and costs 35.99
If you need anything else feel free to PM me or leave a message here. I would suggest ordering the catalog it is very neat and cheaply priced and you can find all types of custom add ons.
Old Nov 20, 2002 | 10:38 PM
  #15
MadBaja819's Avatar
If anyone else is thinking of going this way and adding the additional cooler, please let us know how it works. I will be adding it on in the near future.
Club News and Events
May 28, 2016 08:02 PM
Dammar
Apr 20, 2016 06:03 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
