45mm Carb settings?
Old Dec 30, 2002 | 11:59 AM
BIGBAJA's Avatar
Default 45mm Carb settings?
(lilnotts) Gas usage seemed to be the same. (Get the carb and port your intake[img]i/expressions/face-icon-small-happy.gif[/img]). The only downside is the throttle stiffness, I think after a few more rides it won't seem as bad (need to strengthen my thumb).
Old Dec 30, 2002 | 04:17 PM
Puttnutt24's Avatar
Thanks for the update BigBaja, Did you purchase the 45mm from Ron Woods? and if so, I know he ships them out with a 150 main and a 40 pilot but where is the clip on the needle and what size nozzle does the carb have set up from him?
I just installed mine and I'm about a week away from starting it up. Thx for your help. Rich A
Old Dec 30, 2002 | 04:27 PM
Ds650RaCeR's Avatar
BIGBAJA,
you wont get used to the throttle stiffness!!!!it will KILL ur thumb,i bet i can beat anyone in a thumb war HAHAHAHA..i had to get a twist throttle i could not stand my thumb aiking any long![img]i/expressions/face-icon-small-mad.gif[/img]...ERRR...oh well i like my twist throttle.
Tate
Old Dec 30, 2002 | 06:12 PM
BIGBAJA's Avatar
(Puttnutt24) I got mine used for $250.00, If I were you I would PM (jetsnow600) If you are looking for a 45mm[img]i/expressions/face-icon-small-wink.gif[/img].
Old Dec 30, 2002 | 09:07 PM
  #15
lilnotts's Avatar
i think i need 2 get a better part time job
Old Dec 31, 2002 | 01:38 AM
  #16
DuneMe's Avatar
If you run the 45 w/o the accl. pump you can get a smaller spring (from Ron Wood) and the thumb throttle is fine.
I run a 45 pilot and a 150 main w/o the accl. pump.
Old Dec 31, 2002 | 02:13 AM
  #17
QUADMAN650's Avatar
NO ITS NOT I RAN THE THUMB THROTTLE WITHOUT THE ACCEL PUMP AND IT LIKE TO KILLED ME
Old Dec 31, 2002 | 02:41 AM
  #18
DuneMe's Avatar
Quadman:
Did you get the smaller spring from Ron Wood?
Just got back from 5 days at Pismo and my clutch forearm is more sore than my throttle thumb.
Old Jan 1, 2003 | 04:37 PM
  #19
Domi's Avatar
Duneme, how is the bottem end with your carb setting ( 45 pilot, 150 main)
Is there as little hesitation. I think this carb has great potencial, I run mine w/o the acc pump also and my thumb is fineAfter i put the RWR spring in.
HAPPY NEW YEAR!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 2, 2003 | 12:40 PM
  #20
DuneMe's Avatar
What I notice is if the bike bogs at all and I try to throttle out of it, it just ends up bogging worse (like it is getting too much fuel. This could be the case I guess since lets I am opening up the jet more and the cylinder is not drawing any more air ino itself since the revs are not up.
I think this bog has more to do with cams. Overall, the power is awesome. The low end bog is something I just need to shift out of or slowly roll the throttle out of.
I do a lot of hill climbing and the power for the hills is awesome.
I ran the 45 pilot / 150 main at Pismo and I think I was a bit fat. I would probably jet down one next trip. I just got done jetting up the pilot and didn't think about that when I jetted my main that the pilot would effect the main in that it is aways flowing through it. I usually ride at 4000' so, not used to sea level riding.
