max hp!!
Old Dec 26, 2002 | 09:49 AM
northjeepster's Avatar
Default max hp!!
I've got one question how much increase in hp or speed will i get IF!! with stock bore no nitro or alcohol!!
12.5 to 1 piston two compression rings with thin gasket 13 to 1
45mm slid carb with twist
Race head with larger valves race grind and heavy springs stage 3 race cam
ported polished and matched
rwr exhaust
110 oct leaded gas
Msd ign. with adjustable timing,rev limiter, and studder start
Msd coils
kevlar clutch disks and strong spring
carbon fiber rims with either 22 pure sports or 18.5 hoosiers
titanium sprockes and chain
wave rotor brakes
american star full arms +1
alu. bumpers
LESS head light,air box,black plastic, front tire gaurds
I plan on the engine mods in the next 3 weeks any suggestions thanks!!
[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 26, 2002 | 10:40 AM
BillDS650's Avatar
Default max hp!!
Hp should be in the 50 to 60 HP range. Speed will be a factor of gearing. A stock DS with just taller gearing and tires and a pipe will due close to 100 MPH.
Old Dec 26, 2002 | 10:47 AM
Default max hp!!
you got to be kidding on the hp there should be at least 70 at the rear wheels.
Old Dec 26, 2002 | 10:55 AM
biggerisbetter's Avatar
Default max hp!!
No, Bill is about right.
I would say around the 54 to 56 H.P range. I you go with dual 39's maybe 58hp. But that is ALOT of H.P.!!!!
Biggerisbetter.
Old Dec 26, 2002 | 10:56 AM
Default max hp!!
well then what is stock with piped and jetted??
Old Dec 26, 2002 | 10:59 AM
Default max hp!!
About 39 h.p. give aor take a pony.
Biggerisbetter.
Old Dec 26, 2002 | 11:12 AM
Default max hp!!
what does a stock Raptor and banshee make???
what does a mod to hilt banshee run that is under 500cc ??
And of course no alky or nos!! I doing some research on Bikes that I mit be racing thanks!!!
Old Dec 26, 2002 | 11:38 AM
BLACKDS's Avatar
Default max hp!!
If you make 50-52hp you should be happy! Don't expect much more than that.
Old Dec 26, 2002 | 12:01 PM
Default max hp!!
I need the max hp at the rear wheels!! and I not kidding!!!!! I'll be racing some of the fastest banshee in the states. I cann't change the cylinder or us alky or nos!!!
Old Dec 26, 2002 | 12:06 PM
BLACKDS's Avatar
Default max hp!!
If you don't go with a bore kit then that's all your going to get[img]i/expressions/face-icon-small-smile.gif[/img]
