Got oil?
Old Jan 7, 2003 | 07:43 PM
Bunian's Avatar
Default Got oil?
I purchased my '01 DS a short while ago, and I am making my first oil/filter change on it. I did the change per instructions in my service manual, yet I can't find the capacity for the whole system. I have 3 quarts of oil in it currently, and it will not register on the dipstick. I do get pressure, as my red indicator light does not light when the engine is running. All I really need to know is how much oil does this bike take? The manual is set up fairly well, but it doesn't have a lot of really specific tolerances and capacities on it.
Input appreciated[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jan 7, 2003 | 08:01 PM
Razorcat's Avatar
Default Got oil?
Stock DS-650 Quick Reference
Spark Plug: 2-NGK DR8EA- Gap mm (in): 0.65 (.026)
Cold valve clearance should be between 0.10mm and 0.15mm
Engine coolant capacity- 1.75liters or 1.9quarts
Engine oil capacity- 3.1 liters or 3.3 quartts
Fuel Tank-12.2 liters or 3.5 gallons
Brake fluid- DOT 4
Fuel- Super unleaded 91 octane or higher
Idle speed +-100 1300 rpm
652cc or 39.7 cu. In.
compression ratio 9.7:1
Fan fuse- 15amp
Charging system fuse- 25amp
Old Jan 7, 2003 | 08:13 PM
JMAC650's Avatar
Default Got oil?
When I did my oil change and filter it took close to 4 quarts of oil to fill it up. I think the 3.3 quarts is without changing the filter.
Old Jan 7, 2003 | 08:28 PM
RotaxRulz's Avatar
Default Got oil?
[img]i/expressions/face-icon-small-smile.gif[/img]mine took 3.3 qts without changing the filter, almost 4 with filter change, I just did it last nite, I used 2 2l pepsi bottles cut in half to make a slide for the oil to drain out of the front res and into a bucket, it actually worked pretty good, better than oiling the steering shaft..
Old Jan 7, 2003 | 08:32 PM
Bunian's Avatar
Default Got oil?
Whew! [img]i/expressions/face-icon-small-shocked.gif[/img] That was fast! Thanks a lot for the input, it seems I have another quart to crack open!
Thanks a lot, I'll be sure to announce my input whenever I can.
Old Jan 7, 2003 | 08:38 PM
Razorcat's Avatar
Default Got oil?
on the subject of oil, what kind do you all use?
Old Jan 7, 2003 | 08:54 PM
jetsnow600's Avatar
Default Got oil?
hey rotaxrulz. Its easier to drain the oil out of the res. by undoing the hoseclamp that holds the return oil line to the motor. A lot less messy that way [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 7, 2003 | 09:05 PM
Bunian's Avatar
Default Got oil?
Yes, that is what I did, but I also drained the tank by the plug at the bottom, I like to get the most oil out of the system as possible.
I am using Napa 10W30, since I don't have enough of the real stuff to go around. I plan on ordering a case of Honda HP-4, before my next oil change.
Old Jan 12, 2003 | 07:17 PM
FastYellow650's Avatar
Default Got oil?
when i change my oil, i just run it over to the wash bay at my work and clean her up, sence i do the oil change at work anyways, and not worry about lubing up the sterring shaft
