Decompression pin
Old Jan 25, 2003 | 12:18 AM
Eaglecollector's Avatar
Default Decompression pin
I pretty much did the same thing Sandman....I also put the pin in the freezer for a while so that I didn't have to tap it to much to re-install it. In fact it was working prfectly before I installed the cam. I gave it plenty of time to warm back up to make sure it still moved freely under the sping tension. Only time will tell I guess. Now that I here of biggers probs i'll be worried for sure.
Old Jan 25, 2003 | 05:16 PM
Forcefed's Avatar
when your holding the football - people will throw evrything they can at you to strip it away .... including the waterboy at the end of the bench.
D ya`ll think reinstalling it is a must with a compression ratio of 14:1? I see that some of you are`nt having any starting problems at around 12:1.....but 14:1?
Old Jan 25, 2003 | 05:38 PM
My guess would be that you won't see or notice any diff in the starting at all. What I think will happen is, in time your starter windings will give out. It will take more to turn the starter which in turn will increase the amp draw on the starter. Maybe over amping it and burning out the windings. But all that will take time to occure. How much time is any ones guess, or even if it would actually over amp all.
Old Jan 27, 2003 | 01:27 PM
KenDS's Avatar
FastYellow650,
Sorry for the delayed response, but I was riding! I am running 11.5:1 piston with a milled head, over 200 psi cranking compression. The starter handles it easily as long as your battery charge is maintained. Low amperage from the battery will smoke a starter. It starts on the first push of the button every time, just don't open the throttle. If you open the throttle, it will produce full cranking compression and cause the starter to drag (slow down). Quite frankly it starts better than it ever has. I have been running without the compression release for over two years on the original battery and starter. The increased compression has been part of the package for about 50 hours of ride time. This motor hits 10,000 RPM regularly and I see no need, in my case, to have an unbalanced hunk of metal spining on my exhaust cam slowing down my acceleration.
Old Jan 27, 2003 | 01:37 PM
  #15
biggerisbetter's Avatar
You realize you just Jinxed yourself right??[img]i/expressions/face-icon-small-wink.gif[/img]
I agree with your comments.
Biggerisbetter.
Old Jan 27, 2003 | 01:46 PM
  #16
KenDS's Avatar
[img]i/expressions/face-icon-small-blush.gif[/img] Oops, your right. Can I take it back?
Old Jan 27, 2003 | 03:31 PM
  #17
Sorry dude! your screwed!!!LOL.
You might as well go and buy you a new starter,and Battery.[img]i/expressions/face-icon-small-wink.gif[/img]
Biggerisbetter.
DAFUZZ
Apr 28, 2004 11:48 PM
ccgrady
Nov 6, 2003 11:29 PM
iluv2fly
Jul 30, 2003 01:07 AM
