500 LBS IS TO MUCH!!!!!
Old Jan 23, 2003 | 12:51 PM
JEFFROE's Avatar
Default 500 LBS IS TO MUCH!!!!!
reading about the 04 ds being down around 430lbs from 490 ( mine must be over 490 with nerf bars and ring support rims ect) what weight saving idea's do you know about?
Old Jan 23, 2003 | 03:04 PM
blastnbaja's Avatar
hey where did you get your ring support rims? What do they look like? Do you have any pics.
Old Jan 23, 2003 | 04:14 PM
BillDS650's Avatar
Check out my gallery page it has a photo of the ring I had installed to my stock wheels . You can get the from OMF.
Old Jan 23, 2003 | 04:39 PM
JEFFROE's Avatar
no pic's of my wheels, i had omf weld one ring outside fronts and in and out rear. if i had to do it over again i would'nt. mud rocks get stuck between rim and ring making it out of balance on those fast fire lanes. next time maybe bead locks?
Old Jan 23, 2003 | 04:42 PM
JEFFROE's Avatar
how about a lighter oil tank? between the oil tank,headlight,swing arm it might be 70+ LBS. thats like riding double!!!
Old Jan 24, 2003 | 01:33 AM
biggerisbetter's Avatar
Jeffroe,
I agree to DS needs to loose wieght. I know the swing-arm,and the Axle on the stock DS's are HEAVY!! changing them would save atleast 30lbs, Then you could go to a 520 chain and sprockets(5lbs). Aftermarket shocks(10lbs),aftermarket pipe(7lbs),aftermarket A-arms(5lbs),and steering stem(3lbs)
And you could probably loose wieght by changing Handlebars,rims,tires,Bumpers,etc...(5 to 8lbs)
So lets see, thats about a 68lbs loss!!(not bad)
Biggerisbetter.
Old Jan 24, 2003 | 09:42 AM
BillDS650's Avatar
I did get a chance to weight my DS once with 4 gallons of gas and all the other fluids it was around 490 pounds
