whats in your garage?
#1503
I still have room for a ds650 headlight/bulb,
baja auxillary lower lights
Update, I just ordered a new headlight and a baja auxilary light kit. But one of the front shocks that I just bought of Ebay is bad, so now I need either 1 or 2 different front shocks. I have emailed a few of you for quotes so please respond if you still have them. Thanks,RUSS P.S. I only need good shocks with a good gas charge. UPDATE I now have front shocks as well.
#1508
no more room for 2000 ds 650 with ron wood stage 2 kit, asr upper arms, aluminum airbox that holds battery also,tag t2 bars and mount, aftermarket clutch and springs, full sand tires-extreme 9 paddles and itp sand star fronts, ims bumper, ac pro pegs with heel gaurds, the carb has the pumper activated, 2004 headlight kit, 2005 intake boot. it hit 50 hp and 40 ft lbs on the dyno without the accelerator pump activated and way fat on top end. forgot my jets so i could not rejet. suspected 55 hp. 1 and 2 teeth down front sprockets
#1510
