whats in your garage?
#1771
#1772
#1774
I need, for the TM45 accel pump, the following parts:
-The white nylon pump lever
-The return spring
-the little adjusting screw (i have the spring that goes with it)
-the steel ring between the lever and spring
-a #50 nozzle (i have the 60 and 70, but they are usless to me)
RWR sent me just the rod, the throttle lever pin, the rod boot, and the little spring for the adjusting screw. the carb had the plunger and plunger spring already, so now all i need is listed above.
thanks
-The return spring
thanks
#1780
