whats in your garage?
#2643
#2645
MY SON LOST A TOOTH AND LOOK WHAT THE TOOTH FAIRY LEFT UNDER HIS PILLOW!!! LOTS OF STOCK STUFF
AND SOME PERFORMANCE STUFF!! HERE GOES!! I CAN'T KEEP THIS STUFF!! WHAT DO I DO ??
( I have pics of everything)
1.. STOCK TANK AND COVER ,,BAD SHAPE ( cap and gas valve are worth that)
3..ORANGE FRONT FENDERS AND BRACKETS ( 2 sets)
4.. +5 ACE SWING ARM w/ BRASS BUSHINGS (power coating NEW, GRAY, but has small stress cracks all over powercoat, never put on a bike since new powercoat??)
5.. COMPLETE, BLACK, BAJA DASH WITH TACH, WATER TEMP GAUGE, BOOST GAUGE,KEY IGNITION, LED VOLT GAUGE WARNING LIGHTS , (redlight needs replacing,, LOOK FAMILIER JUSTIN??)
6..STOCK HEAL GUARDS
7..STOCK BAJA HANDLE BARS w/ guards
8.. OILTANK
9.. REAR GRAB BAR
10..RADIATOR ( BAD SHAPE)
11..STOCK CLUTCH (good shape)
14..PING AND STOCK GAS VALVE (ping does not leak but will not shut off all the way)
16..STOCK HEADER w/ heat shield
17..STOCK CARB, INTAKE MANIFOLD
19..ORANGE SKID PLATE
20..CARBON FIBER Kit DASH, HEAT SHIELD, TANK COVER AND FRONT SPROCKET
23.. 2 M.S.D. IGNITION'S' COMPLETE WITH COIL AND NEW GRAB BAR MOUNT
( one works PERFECT, but the other box not working).
24..STOCK CLUTCH CABLE w/LEVER AND CLUTCH SWITCH
25..RADIATOR GUARD w/6" SPAL PUSHER FAN MOUNTED FOR DUEL FAN COOLING( needs paint or powercoating, fan is new)
26..COMPLETE WIRE HARNESS FROM A 03 BAJA W/ ( rectifier and fuses)
27..STOCK THROTTLE CABLE( carb lead end missinG)
8.. OILTANK
9.. REAR GRAB BAR
