whats in your garage?
#3751
Updated list of what needs to be moved out of the garage...
*Stock baja handguards - used 2 rides
*Sandstar front(23") and Sandstar rear paddles(22") on .190's
*Sandstar fronts on .190's - 2nd set
*Hauler Extremes(22x11x10) rear on .190 yamaha bolt pattern rims
*Douglas .190 rear rims w/ Bomb bolt pattern
*Ron Woods CDI - backup cdi, used twice.
*Trailtech 1 1/8th billet handlebar mount - 2 of these.
*+2 ATV Four Play anti-vibe steering stem, powdercoated gloss black (partial trade for stock stem).
*1 K&N Filter - stock replacement
*Stock Baja tach.
*520 conversion w/ lightest 520 x-ring chain available, aluminum rear, steel front sprocket - Used a few rides (do a search on my name and you can read all the work that went into this combo).
*HMF slip on exhaust, powdercoated black w/ quiet core.
*RPM rear regular grab bar, brand new.
*Front brake lever and master cylinder.
*Billet Aluminum Gas Cap w/ stubby breather hose.
I need the following in my garage...
*Stock steering stem.
*Stock chain and sprockets.
*Stock yellow baja x seat cover or black one.
Thanks,
Josh
*Stock Baja tach.
Thanks,
Josh
#3756
2005 DS650
Wood CDI
HPR3 cams
HPR 14/1 piston
The Bomb porting
Big valves
Ported intake
TM48
Chromoly Aarms
Chromoly +6 swing arm
JJ&A drag axle
Drag pipe
Lightened fram and sub frame
Custom painted plastic
Renthal bars
Boon Dockers nitrous system
K&N
Billet gas cap, rear res cap and dip stick
Chrome side covers, grab bar, oil filter cover, Aarms and swingarm
Gripper seat cover
Chrome brake pedal and shifter
Pingel pitcock
Douglas rims
Ohtsu tires
Billet rear hubs and lightened front hubs
Led lights
Powder coated fram and sub frame
Auto meter oil pressure gauge
Braided rear line and custom brake rotor
Marvin shaws rear
Billet bar riser and clamp
This thing is very nice and a runner. You wont see a better looking DS anywhere and it needs to go. It has the best parts on it. PM if you would like to take it home
Wood CDI
HPR3 cams
HPR 14/1 piston
The Bomb porting
Big valves
Ported intake
TM48
Chromoly Aarms
JJ&A drag axle
Drag pipe
Renthal bars
K&N
Gripper seat cover
Pingel pitcock
Douglas rims
Ohtsu tires
Led lights
Marvin shaws rear
#3757
#3758
