whats in your garage?
Old 04-12-2008, 01:38 AM
kansasds650's Avatar
Default whats in your garage?
I need a right upper a-arm for a 2000 ds 650 in my garage.
Will the 02 & ups fit ok if I just change 1 side?
Thanks
Kenny
  #3862
Old 04-12-2008, 02:53 PM
tombomb's Avatar
I need in my garage one set of 25 inch double buff paddles on bomb wheels.
  #3863
Old 04-12-2008, 07:45 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
I need some 25-11-9 14 paddle rippers staggered or something equivelant. even the 16 paddle will do. they will make my garage purdee.
  #3864
Old 04-12-2008, 10:29 PM
amd's Avatar
amd
amd is offline
I still have:
lightened rear hubs for drag racing on a honda pattern
42 tooth aluminium rear sprocket 520 chain
Rear brake rotor
Rear brake hub
Front baja bumber
rear grab bar
front brake rotors
front break calipers with good pads
530 chain for an 04 or later
530 steel 40 tooth rear sprocket
530 16 tooth front sprocket
tail light
All of it needs to be in someone else garage.
  #3865
Old 04-13-2008, 09:45 PM
Goodsound's Avatar
Set a New OEM chassis 4 stroke national record on his OMW DS855 - 3.93 !
Ill give you $500.00 for the grab bar if you though the bumper in free.
  #3866
Old 04-14-2008, 12:45 AM
NickDS650's Avatar
#1 that should be a PM
#2 for that much money i'll give ya every bumper and grab bar i have haha
And i still have some '03 parts left if anyone needs anything, plus my accessories off my '02 Baja
  #3867
Old 04-14-2008, 08:59 AM
saint650's Avatar
NEED A CLUTCH LEVER, ANYONE HAVE ONE?
  #3868
Old 04-14-2008, 02:49 PM
DragonDJ11's Avatar
This stuff is just collecting dust in the garage...
Full RWR Exhaust with both the open end, and supertrap end. It is used and has some rust on it. A good sandblast and powder coat would have her perfect. And a couple dings here and there.
LTE Exhaust system. Used for no more then about 2 hours.
HPR Lectron 48 with a 1-5 needle in it. Cable and RWR ported intake also sitting around in the way....
  #3869
Old 04-14-2008, 08:07 PM
tombomb's Avatar
[img]i/expressions/face-icon-small-confused.gif[/img]
  #3870
Old 04-14-2008, 11:04 PM
DSNUT's Avatar
I have a full Alba system that is actually a good running pipe. It has a good header and the slip-on portion expands similarly to the Top-Gun pipe for scavanging purposes.
The pipe is in good shape but its biggest downfall is that it is LOUD!!!
Good performer but if decibal limits are an issue, look elsewhere.
I need it out of my garage.......[img]i/expressions/face-icon-small-smile.gif[/img]
Quick Reply: whats in your garage?
