whats in your garage?
#4362
Yes i have and that thing is sweet Bike seems to run alot smoother. Now she will take off like a rocket. Thanks Stir
Plus the wife said i will not wake the neighbors now LOL
I will take pictures this weekend and post them i had to cut the grab bar to make it fit.
Later
Bioware
#4364
#4365
#4366
2 handlebar clamp covers / steering stem covers
2 timing chains
2 timing chain guides (sets)
2 chain tensioners
2 motor mounts w/ bolts
2 battery holders
crankshaft balancer
cam bridges
wiring harness
2 air box lids
both crankcases, 1 with tranny still intact
motor / tranny individual gears
oil pump gears
ignition cover w/ stator assembly
jug with both gaskets
valve / head cover
rotor, flywheel hub, clutch housing, and starting gear
stock front / rear sprocket set
rear axle w/ sprocket star
clutch perch, stock exhaust baffle
foot pegs, foot shifter, front bumper ('01)
rear wheel hubs, front wheel hubs/rotor/spindles assembly
'01 frame (NY title, registration, plate), subframe, swingarm w/ bolt
front and rear Baja rims, radiator w/ guard
front brake assembly - lever, master cylinder, lines, calipers
rear brake assembly - master cylinder, lines, fluid tank, caliper and support
2 timing chains
2 chain tensioners
2 battery holders
crankshaft balancer
cam bridges
wiring harness
2 air box lids
oil pump gears
valve / head cover
#4367
#4368
#4370
OMW Desert Race/Hill Climb +1 valve Head, with shim-unders
I do not really want to, but somethings are more important.
the head has about 5-10hrs on it, and has just been refreshed by Eric@OMW. The head is the OMW Desert Race/Hill Climb +1 valve Head, with shim-unders. The cams, cam chain bridge between the cams and valve cover/gasket are not included
Another trail ported head by KMS with Shim under
A vortex CDI
Various other parts
A vortex CDI
Various other parts
These are going to be headed to E-bay tonight.
