whats in your garage?
Old 08-19-2009 | 12:58 PM
BBR650's Avatar
Is always changing bikes.
Originally Posted by BBR650
ATV Drag Racers
ATV Drag Racers
ATV Drag Racers
its for sale! mainly just because i have lost interest due to some certain reasons.
Chassis
lightened stock frame
chromoly subframe built by The FOG
wheelie bar built by The FOG
Drag Steering stem built by The FOG
Chromoly A-arms and spindles
CP Customs +4 swingarm
shaws all around
aluminum battery/electronics box mounted under the seat
Douglas 10x2 spindle mounts with 18" buffs
JJ&A drag axle
a set of 4-snows on ITP .190s will come on the rear
PERFORMANCE
Stock motor, with fresh rings gapped for nitrous
Vortex ignition programmed for Motor curve and Nitrous curve
48mm Mikuni HSR carb and ported intake
Pingle Fuel valve
Ron wood drag pipe
520 9800lb chain and sprockets
Boondockers Nitrous kit on full throttle switch
Barnett 9 disk kevlar clutch kit
did some bracket racing this weekend. track was hard and 60fts were off for everyone. my last pass the guy red lit (first infraction) so i ran it out the back door with a 1.778 60ft 59.xx mph @ 5.10 et ON STOCK MOTOR, no nitrous!!!!
before it was set up on a 15hp shot and was picking up 4 tenths on the spray. it now is set up on the 20, just havnt had it at the track on the spray since!
still has more in it track was just tight and the tires wouldnt get down and dig off the line!
$4,000
Board Message
link to pic's and build topic
  #4422
Old 08-19-2009 | 05:20 PM
flux's Avatar
also have a reusable oil filter for the DS 650...
  #4423
Old 08-19-2009 | 10:45 PM
flux's Avatar
i have the owners manual and the clymers manual for
the BMW MOTORCYCLE the rotax 650 also powers...
i think its the GS 650, its a very good motor manual,
better than the factory book......
  #4424
Old 08-23-2009 | 09:30 PM
Psycho-Son's Avatar
Default 48mm lectron carb
i was just wonderin if you decided to part that bike out, how much you want for the carb, and what condition is it in?
  #4425
Old 08-28-2009 | 05:38 PM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
Default +4 swing arm
I have a +4 swingarm for the older model ds650 with new bushings I need somebody to take from me $300.00 shipped
Brian (916)521-4733
  #4426
Old 08-29-2009 | 01:00 AM
alaska-DS650X's Avatar
how much?? i am looking 4 ds650 parts of all kinds(engine,tires,shocks) thanks rod-alaska-DS650X
  #4427
Old 08-29-2009 | 02:17 AM
flux's Avatar
sent you a PM with parts and prices.....
let me know...
thanx....
chris...
  #4428
Old 08-30-2009 | 02:19 AM
NickDS650's Avatar
few leftover '01 parts - body and motor, then the complete '03 with powdercoated parts, lemme know what you need
  #4429
Old 08-31-2009 | 08:53 AM
justme23005's Avatar
I have an 05 engine, a set of works front shocks, almost new headlight (fits older style), red, black, & orange sets of plastic, Pro Circuit T-4 pipe, & an air box with filter & hoses. skidooguy30m@yahoo.com
  #4430
Old 09-03-2009 | 01:37 AM
NickDS650's Avatar
front and rear douglas rims, 23" Maxxis Razr fronts, 22" Maxxis Sur Trac rears, stock front and rear rims, stock front tires, 18" Maxxis Razr MX rears along with my '03 part out
