Bore VS Stroke
Old Feb 14, 2003 | 09:44 PM
Hurycne's Avatar
Default Bore VS Stroke
Which makes do you think makes more power? A 3mm bore or 3mm stroke?
Old Feb 14, 2003 | 10:32 PM
Ernie660R's Avatar
I have read that it is better to have the piston at top dead center and bottom dead center longer. [img]i/expressions/face-icon-small-smile.gif[/img]
Hope this helps.
Old Feb 15, 2003 | 02:38 PM
dsmike's Avatar
the only thing that makes a piston stay at TDC longer is a longer rod.
stroke will build more power.
Old Feb 15, 2003 | 05:13 PM
Ernie660R's Avatar
You are very right DSMike, but it can be expensive as well. Really anything that you do to an engine whether it my be changing the bore or stroke or even adding a longer rod, it will be expensive.[img]i/expressions/face-icon-small-wink.gif[/img]
I guess changing the bore seems to be the most popular choice.
Old Feb 15, 2003 | 11:59 PM
Hurycne's Avatar
IS it also true the close a motor is to square the power it can rev and the more power it will make?
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
