WHO IS COMING TO SNAKE HUNT????
#31
so your getting a drag chassis for the RED R? i guess i will have to pick on your dad now. the last time we was racing your red R i was staying fairly close. but know i know you have done more and got your carb tuned in better.(i guess you still running the packard lectron?)
what size is it? i have to 40mm and will need help tuning them.
#33
MUDSTUD- we talk about trx250rjb because he is probably the fastest single cyclinder guy at LS. even know we have about 300cc bigger motor he is still to much for us.
he is one of the only guys that will go run wiht the drag banshee thats not a drag banshee.
#35
Yea, we are getting that drag chassis for the 350 alky bike. we are getting a few other light weight components. i put the lectron on our alky 250 bike. hoping to do some tuning on it soon. we went back to the old keihen on the 350. it loads up pretty bad but runs hard. we went up one tooth on the front sprocket and it would still pull out of the hole just as well, so it should have more top end than it did. we are getting the side drag pipe chromed. also going to do a little more tweaking on the port work. it should run pretty well. we have been thinking about putting the white bike on alky again. it had some serious top end last time out with the alky. have you gotten Triple talked into building you a chassis yet??
#36
he said he would build it, its just the funds. that kinda cash isn't easy to let go. LOL
and if i got it the other 4 strokes probably wouldn't want to race. then i would be stuck get sand from you. atleast now i can back up into another group of races out there.lol
