Hard to start
Old Apr 5, 2003 | 12:23 PM
racerx5x5's Avatar
Default Hard to start
I have a 2000 DS, When it is cool out my DS is very hard to start. Any ideas?
Old Apr 5, 2003 | 12:35 PM
SANDMAN430's Avatar
check valve clearance, and maybe a larger pilot jet. new plugs. should be in there some where
Old Apr 5, 2003 | 12:37 PM
JEFFROE's Avatar
if you have to hold you'r hand over the mouth of the carb to get it started you need to check valve clearance.
Old Apr 5, 2003 | 12:40 PM
racerx5x5's Avatar
Thanks, Dose any one know what the valve clearance is?
Old Apr 5, 2003 | 01:05 PM
SANDMAN430's Avatar
the manual says .10-.15mm or .004-.006 in. you need to have the piston locked at top dead center. there is a locking bolt on the bottom left of the engine case. do a search and you will find a lot of info on this subject.
Old Apr 5, 2003 | 01:20 PM
DuneMe's Avatar
Did you recently improve flow? (New pipe, air filter, etc.) This will let more air in at the low end as well at the high end. I have noticed a big difference in Pilot size when I change something. I had recently checked my valve clearances and all was good.
Are you running the stock carb or the TM45?
If you have the TM45 a 40 pilot is probably needed.
Also, check your air mixture screw.
If however, you have never checked your valve clearances on your DS. . . it is probably that.
Old Apr 5, 2003 | 01:25 PM
racerx5x5's Avatar
All stock still I'am the 2nd owner and I haven't checked valves yeat.
Old Apr 5, 2003 | 01:29 PM
SANDMAN430's Avatar
hey dune me they put a 47.5 pilot in my 45mm i have noticed i don't need the choke what does this do at other points, it seems to start when it is warm. but was wondering if i'm losing somewhere else? i live in acold area it is at freezing most mornings but when i go to the coast it seems fine.
Old Apr 5, 2003 | 01:35 PM
racerx5x5's Avatar
What size is a stock jet?
Old Apr 5, 2003 | 01:39 PM
SANDMAN430's Avatar
i think the stock pilot is 40 i have a 50 in my stock carb. the main is 165 small round
