"Oshotsu - Stock" VRS "RAZR - Stage 1"
Old 04-07-2003, 04:26 PM
MudStud's Avatar
Default "Oshotsu - Stock" VRS "RAZR - Stage 1"
I think it would be the reverse.. When I set my suspension it actually increased its hole shot ability and reduced wheel spin..
Old 04-08-2003, 12:23 PM
fastone21's Avatar
Mud Stud
With a stage one kit you are making more power and torque down low thatn stock. Try this set up. Keep the 22 in tires and run 15/40 gearing, 1st through 3rd you are geared so low that you are blowing your tires off. Gear up add take advantage of the extra power you have and you will stayin your torque range longer. The ds is will turn more rpm with the rev limiter but 8500 is the ceiling in my opinion. Take of in secon gear around 5500 and see how this works for ya.
Old 04-08-2003, 03:19 PM
MudStud's Avatar
I had 15/40 gearing but was not able to rev it out in 5th gear on the top end. So I went down to a 14 front..
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
XxS0ccerstarxX
09-08-2015 12:02 AM
Elkaholic
09-06-2015 02:44 PM
Quick Reply: "Oshotsu - Stock" VRS "RAZR - Stage 1"
