modify a cdi
Old Apr 8, 2003 | 02:20 AM
  #21
bigben's Avatar
Default modify a cdi
Last I heard, the Vortex was more $ than the RW. I think ~$350 compared to $263.
Old Apr 8, 2003 | 11:11 AM
  #22
SANDMAN430's Avatar
i think i'll go check some locations to see if they have any new products, i would like to read about the new cdi.
Old Apr 8, 2003 | 12:31 PM
  #23
rednvegas's Avatar
Originally posted by: CrazyWhiteDude
I could probably get ahold of somebody that can do the prom stuff. But what were you saying he would have to do, tear open a rwr and copy it. then put it on the stock one.
Somebody said there is more that one curve in the stock one. It kinda sounds like alot of work especially if I had to buy a rwr in order to copy it. I thought it would be easy to just reprogram the stock one.
And if you have a vortex why don't you give me a deal on your old cdi(marky or anybody)?
Actually are the vortex as much as a rwr?
I have everything thats the way i built mine and my friends you only have to break rwr once, Once you have the programs copied then you can burn new eeproms for any stock cdi box and it will turn into a rwr.
Old Nov 2, 2003 | 03:43 PM
  #24
Baja2002's Avatar
Yes, it's possible to reprogram the stock CDI. I send my CDI last week for a new program.
The new cut off will be 9400rpm'S
and you can choose de timing advance if you want.
Old Nov 2, 2003 | 05:03 PM
  #25
muddeep's Avatar
baja2002, coud u send me info on the place u set ur cdi to get it reprogrammd.
Old Dec 1, 2003 | 01:14 PM
  #26
Maddog419's Avatar
Did anyone ever get there cdi reprogam. Thanks for any info on this
later
Old Dec 1, 2003 | 03:45 PM
  #27
Gasser's Avatar
THE REASON THEY HAVE A REV LIMITER IS BECAUSE THE VALVES FLOAT AT ABOUT 8500 RPM'S! I LIKE IT WHEN ALL THE GUYS PUT IN A BOX WITH NO LIMITER ,BECAUSE THE NEXT THING THEY DO IS BEND THE EXHAUST VALVES.THIS IS THE NEW REV-LIMITER A PISTON WITH EYEBROWES!!THE BEST MOD IS TO GET THE POWER TO THE GROUND,TIRES. 22"EXTREME 9 PADDLE.
Old Dec 1, 2003 | 06:32 PM
  #28
Maddog419's Avatar
Come on Gasser: you can put handen springs in. And also a tach/shift light. Thanks
later
Old Feb 9, 2004 | 04:08 PM
  #29
berksglh's Avatar
Does anyone have any info on the PROM in the stock cdi boxes. Manufacturer or part mumber?. Its a 42 Pin DIP and only has Nipendenso Numbers on it.
I'm Trying to extract the hex code for my own exparimentation with the timing tables. We did this with our turbo Dodge ECM's, but that was all 27hc256 stuf, and there was a lot of info available about it.
Any info apreciated.
Old Feb 9, 2004 | 04:19 PM
  #30
ironrod's Avatar
Originally posted by: 1prokiwi
Marky , I have the book with specs for the "new 03 model" and it says the rev limiter is set at 7700 not 8000 ?? where do u get your info from ???
I do agree that u have to have an aftermarket CDi to get the beast to work in the meat of the power ...night and day difference to me .....
Cheers
Prokiw
03 was a tricky year. Add the fact that the manuals aren't always updated. The yellow standard DS '00 and '01 was 7700. There were some late model yellow ones that managed to get the newer rev box. The Baja, Viper, and BajaX is 8000 - all of them. The limit was raised by 300 rpm - thats from a source at Bombardier.
