Clutch case problem!
Old Apr 9, 2003 | 01:02 PM
ThePunisher's Avatar
Default Clutch case problem!
Has anyone broken off that tab that holds the cable on the clutch case? Is that case made of aluminum or Magnesium? If you did break it off how did you repair it? Thanks.
Old Apr 9, 2003 | 01:23 PM
SAMCOEDS's Avatar
i replaced mine elliott at ron woods keeps them in stock.
Old Apr 9, 2003 | 01:46 PM
He keeps clutch cases in stock?
Old Apr 9, 2003 | 01:47 PM
jiminok's Avatar
Angry...are you talking about the molded into the case split ring that the cable slides into, or the actuator lever? I believe the cases are aluminum...you should be able to get it welded there in L.A....dang youre having some crappy days!
Old Apr 9, 2003 | 01:59 PM
jetjock16's Avatar
Hey angry, if your talking about the little peice that holds the clutch cable to the case, mine broke off the first month i owned the DS, I zipped tied the cable to the oil line which is right there and it has been like that for almost two years, it never lifts over the little detent and the only thing holding it is a little pressure and that zip tie............. If it keeps workin i aint gonna replace the whole case
Jetjock16
toonces
Oct 16, 2019 12:11 PM
coolguy420
Jul 10, 2015 01:17 AM
Land_shark1
Jul 10, 2015 12:53 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
ranvette
Jul 4, 2015 06:13 PM
