ds 650 question help please
Old Apr 16, 2003 | 02:41 AM
dsx's Avatar
dsx
Default ds 650 question
ijust bought a 2001 ds 650 the choke was stuck open so i changed the oil a couple of times and now the oil pressure light comes on after i ride it for a half an hour ive heard your supposed to bleed the oil system if the light comes on and stays on but it dosnt come on for a while the first time it came on is when i noticed it had gas in the oil how do you get the bleed screw loose
Old Apr 16, 2003 | 06:38 AM
rednvegas's Avatar
Default ds 650 question help please
if you have gas in the oil you have even bigger problems ,like a cracked head or the sleeve
Old Apr 16, 2003 | 07:25 AM
SANDMAN430's Avatar
that red light also means the water is getting hot in the cooling system.
Old Apr 16, 2003 | 08:56 AM
barbwire44's Avatar
I'm with sandman on this one, if the light doesn't come on for 1/2 hour after you run it sounds like water temp to me , easy way to find out just unplug the wires from the oil switch and see if it goes out ,if it does it's the water system. I just went through the bleeding process last weekend, I just used a very large screwdriver that fit the slot nice and tight put a pair of pliars on the handle started twisting while tapping the end of the screwdriver with a hammer, Busted her loose easily.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
