Fresh rebuild difficulties! Need feedback!!
Old May 12, 2003 | 02:47 AM
ThePunisher's Avatar
Default Fresh rebuild difficulties! Need feedback!!
I think we might be on to something I hope! I looked in the manual and apparently there is a screen in the Oil Tank itself! I think from the last time when his engine had spewed a ton of coolant in his oil that it somehow may have collected and wasn't letting oil get down into the motor. Just enough though to keep it from Seizing. Mario is supposed to call me back here in a little bit and let me know what he finds. The only other thing it could be is the Oil pressureregulator and if that is the cas e then that REALLY SUCKS!!![img]i/expressions/face-icon-small-mad.gif[/img] Because then you have to split the cases!!!! I would like to get some high pressure air and try and blow thru this thing and possibly clean it out. We will know something by tommorow I hope!!!!
Old May 12, 2003 | 10:58 PM
Majorecho's Avatar
so was the oil filter in the reservoir plugged?
Old May 13, 2003 | 12:59 AM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
yes oil filter in res was plugged and the light went off when i un plugged it.. we then went to test ride it and it felt like the motor was tightening up ,losing power and running a bit hot when idleing we think it might be damaged berrings..if you have any ideas it would be much appreciated,.. thanks in advance
Old May 13, 2003 | 01:24 AM
Majorecho's Avatar
so did you find any brass specks in your oil when you changed it? my experiance with brass is that when it overheats it will bind and sieze your crank - apparently you didn't get to that point but I wouldn't be running it until you split the cases and inspect it- I know big bummer!
If I were you I take whomever built your motor out behind the woodshed and kick their ..... then I'd sue them to the fullest extent of the law for all damages,emotional distress, anxiety, loss riding time, fuel wasted and any thing else you can come up with- these fly-by-night builders have to learn thay can't get away with this kinda crap.
No, kidding aside bite the bullet and tear it down and go over everything thoroughly- hope the damage is minimal
[img]i/expressions/face-icon-small-sad.gif[/img]
Old May 13, 2003 | 10:12 AM
  #15
wshrdskin's Avatar
Damn, better run and hide Tony. [img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img] j/k
Old May 13, 2003 | 11:09 AM
  #16
marbleous's Avatar
Tony if I was you I would trade your bike for Mario's.,until you it can be fixed
AGAIN. By the way how
did your night run go last night'. I think Mario called me up last night,I was sleeping like a baby.
Hey Mario you should just leave that damn bike alone and just start riding it, enjoy that
big bomb.
Old May 13, 2003 | 03:49 PM
  #17
raptor03's Avatar
lmao!!!!GOOD ONE DAVE..
Old May 13, 2003 | 09:12 PM
  #18
Hey Curtis, Let me tell you what. There is a ton of brass shavings in the plug! So I believe that when the strainer in the tank got clogged it starved out just enough oil to fry his bearings!! This really sucks! I will tell everyone right now, CLEAN THE OIL STRAINER IN YOUR OIL TANK AT EVERY OIL CHANGE!!!!!!!!!!! VERY IMPORTANT!!!!!!! That strainer gets clogged up with filaments from your filter after time and you will start starving your engine. An NEVER us the same oil filter twice!!!! NEVER!!!!
Old May 13, 2003 | 09:13 PM
  #19
Hurycne's Avatar
I just got mine apart and I think all my brass shaving came from the rod bearing...good thing I am putting in another crank.
Old May 13, 2003 | 09:14 PM
  #20
Hurycne's Avatar
I used the same filter twice[img]i/expressions/face-icon-small-frown.gif[/img]
