Rear brakes on a mini 90, not working correct
Old Feb 6, 2006 | 05:31 PM
imesinga's Avatar
Default Rear brakes on a mini 90, not working correct
Just put together a kids mini 90 and have a brake problem. Brake lever has little to no resistance. Bleed the brakes several times, not hearing any air, but flow from bleeder is very slow, yes the brake lever is depressed. You can pump the brakes about 3 times and they get real tight, ride 20 feet then start all over again with no resistance. It's as if the piston in the caliper moves forward, but does not retract when you release the break lever. Could there still be air in the lines, if not what in the world would cause this?
Old Feb 6, 2006 | 10:24 PM
imesinga's Avatar
Lots of looks, no replys. C'mon 2many I konw you've got a how to fix brakes post in you.
Old Feb 7, 2006 | 02:56 AM
Bobmack's Avatar
sounds like a restriction in the brake line some place, or the master cylinder is bad
pump the brakes up to then the brakes will whole the bike and then bleed it and see if they release
if they do then it is in the line or the master cylinder if it doesn't its in the caliper
Old Feb 7, 2006 | 10:10 AM
RacewayATV's Avatar
imesinga did Vinny take care of you?????
Old Feb 7, 2006 | 11:26 AM
imesinga's Avatar
Yes John he did, hadn't had a chance to check them or post yet. But as always the gang at raceway came through with some help. When I run through what Vinny gave me I'll post the results.
Old Feb 9, 2006 | 02:11 PM
imesinga's Avatar
Seems like Vinny's solution helped out John. I'm not sure my hand will ever be the same after bleeding the brakes for almost an hour. But they seem to have a better grip now.
txkevin
Sep 21, 2015 02:02 PM
AK47KID
Jul 23, 2015 09:21 PM
scaldwellk
Jun 19, 2015 05:08 PM
UPLou
Jun 7, 2015 09:42 AM
CountryMiles
Oct 25, 2000 01:03 AM
