Meerkat 50 no longer runs - valve work needed?
Old May 10, 2006 | 10:15 PM
ChrisEdgington's Avatar
Default Meerkat 50 no longer runs - valve work needed?
We have two meerkat 50's - they've been running great since resolving intake problems last summer.
Last weekend we rode for a couple hours, now one of them won't run. It turns over, but won't do anything else. I've confirmed that it is getting a spark, and that it is getting fuel. When I compare the compression manually (by holding my thumb in the plug hole) between the two - the one that won't run seems to have less compression. A friend of mine said it probably needs the valves re-seated or something like that. Can anyone help me figure this out?
Thanks,
-Chris
Old May 10, 2006 | 10:42 PM
RacewayATV's Avatar
If you give me a call tomorrow I can shoot you an email with a little help on this!
Kazuma ATV Raceway ATV
Old May 10, 2006 | 11:19 PM
2manytoys's Avatar
One of the only problems with these is that the valves need to be adjusted about once a year. It is very easy to do. Im sure John can walk you through it. Once it is done it will run like new. This is just mantenance.
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
momofo
May 27, 2015 12:06 PM
