SUNL 90 Nothing!
Old Jun 28, 2007 | 10:00 AM
tamclau's Avatar
Default SUNL 90 Nothing!
My 1 year old Sunl 90 Won't crank. My daughter took it for a ride and the next day nothing! I checked the fuses on the posotive lead, the connectors under the handle bars. The battery is showing good, but, no lights, no brake light when squeezing the brake.
Need Help. Thanks.
Old Jun 28, 2007 | 10:19 AM
billl2099's Avatar
what you expect buying a sunl? after 1 year i'm surprize it not in the trash yet, are you keeping a close eye on the frame? they like to break at the swing arm, oh by the way you need to replace the battery, walmart has them __4lbs or you can use a __5lbs both the same size but the 5lbs has more cca
Old Jun 28, 2007 | 10:23 AM
tamclau's Avatar
OK, I understand what I bought. I posted for help, not for a chance to be bashed for my purchase. We all make mistakes. I am just looking for a little help. I have a 6 year old that wants to ride.
Old Jun 28, 2007 | 11:04 AM
outofline's Avatar
My Edit!
Try looking at the Solenoid, it's between the battery and the starter. sound like if the battery is in fact good as you say you may have a bad connection there. I agree it sounds more like a bad battery though!
Old Jun 28, 2007 | 11:17 AM
bigborehonda20's Avatar
When you have it hooked to the charger do you get any power? It sounds like a bad battery or could be a loose ground wire somwhere.
Old Jun 28, 2007 | 04:06 PM
pimpsmurf's Avatar
Yeah, check all your connectors. You might have to take a panel or two off to see them, but there may be a connector missing. I had it happen to me too. =)
-JNY
Old Jul 2, 2007 | 12:10 PM
tamclau's Avatar
OK, I had some time over the weekend to look into this a little. I took all the plastics off and got to the solenoid. I jumped the solenoid and the starter turned, so, I think I have proven two things; 1- the battery is not the problem and 2-the solenoid is good.
So I am guessing it is either in the safety circuit on the handbrake or in the key switch circuit. Is there an easy way to "jump these circuits to try to narrow it down?
Am I on the right path?
Tom
Old Jul 2, 2007 | 02:47 PM
pimpsmurf's Avatar
If jumping the solenoid caused it to turn over, then you might need an ignition switch. You need to be carefull how it is wired up, if you are not using a direct replacement part (with plug.)
It could also be the safety circuit. Does the ATV require you to hold a break or something to start it? You would probably short those connections to be sure before buying anything. I don't know a whole lot, but I hope this helps you get a place to start.
-JNY
Bigredjeep
Apr 10, 2020 02:55 AM
Atvnewb88
Aug 19, 2015 02:22 AM
Atvnewb88
Aug 13, 2015 06:48 AM
WILLLANE8302
1) Engine problems..
Aug 7, 2015 08:24 AM
Mobyguzzer
Apr 28, 2006 11:25 PM
