Jetmoto hard to start? Look into this.
Old Sep 2, 2007 | 10:36 PM
00XJ's Avatar
Default Jetmoto hard to start? Look into this.
My 250 Sport had become hard to start, and wasn't running as good as it had been. I discovered this AFTER I completely filled the tank with gas.[img]i/expressions/devil.gif[/img] Had to drain the tank back out.
I thought the gas line had split because it was leaking gas. Turns out it was not the line it was the filter. I replaced the filter, and the starting/preformance issues went away, it runs as good as ever. Apparently something came loose inside the filter and was blocking fuel flow. I know it wasn't plugged up with gunk.
Just a little FYI if you're having any starting/preformance issues.
Old Sep 3, 2007 | 09:48 PM
hoytultratec's Avatar
i noticed the filters used on the china quads are crap also i also replaced all of them with briggs and stratton small engine filters and all have worked excelent fo a year and a half.
Old Sep 3, 2007 | 10:36 PM
00XJ's Avatar
Little off topic... Not a bowhunter are 'ya?
Old Sep 3, 2007 | 11:08 PM
komatzu's Avatar
I also had trouble with my 250 sport and my 2005 250 hunter. They would start ok but stall after 5 minutes of riding and not restart. Let it set for 5 minutes and would run again. I replaced fuel filters with K and K filters and bypassed the fuel shut off and they ran great. Take off the fuel shut off valve and on mine the hole was not drilled right to line up with the fuel line when it was turned on. I took both of mine and turned them to where the fuel was on and ran a drill bit through the valve. Now the work great!
Old Sep 3, 2007 | 11:16 PM
00XJ's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: komatzu
I also had trouble with my 250 sport and my 2005 250 hunter. They would start ok but stall after 5 minutes of riding and not restart. Let it set for 5 minutes and would run again. I replaced fuel filters with K and K filters and bypassed the fuel shut off and they ran great. Take off the fuel shut off valve and on mine the hole was not drilled right to line up with the fuel line when it was turned on. I took both of mine and turned them to where the fuel was on and ran a drill bit through the valve. Now the work great!</end quote></div>
I noticed some of what your saying about the shutoff valve. The "hole" is not very big even compared to the ID of the fuel line. I hadn't thought about opening the hole though. Hummm...
Old Sep 4, 2007 | 12:02 AM
komatzu's Avatar
Mine were so small you couldnt get a piece of wire through them. Just run a bit through about 1 size smaller than the valve and they will work great.
Old Sep 4, 2007 | 06:31 AM
outofline's Avatar
I also had to replace my filters, one of the 250's started leaking!
Old Sep 4, 2007 | 08:28 AM
jetmotoracer's Avatar
i replaced my filters gecause the fuel has been crap latley they are at 20 % ethanal and going to 20% (so iv been told.... when i put the new filter onn and put the fuel back in i had to drain some of the fuel because there was so much rust in it in the beginning[img]i/expressions/face-icon-small-confused.gif[/img]......(p.s, theyu had the origanal filter on upside down.... i think)
Old Sep 4, 2007 | 06:10 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
My stock spark plugs lasted longer then the fuel line and filter. Some of the stock filter's are hard to blow thru.
Old Sep 4, 2007 | 09:41 PM
oh yeah, 2 more weeks till season starts.
