HELP IS NEEDED!! PLEASE HELP!
Old Oct 1, 2007 | 08:13 AM
soulja's Avatar
Default HELP IS NEEDED!! PLEASE HELP!
I had brought an 110cc bmx atv from bestpriceatvs.com, when i got it it worked fine, but the second day i was riding for a little while then i decided to turn it off, but it never cranked back up. The lights will come on but all i'm hearing is a sound from the slonoid when i press th electric start button. (new battery and charger) CAN ANYONE HELP ME PLEASE ATV IS DRIVING ME CRAZY!!!!!!!!!!!!!!! it is also making a clicking noise when i try to start it!!
Old Oct 1, 2007 | 09:48 AM
outofline's Avatar
Try Jumping the atv with a Charger or another battery, these Chinese atv batteries are known to be junk and it may just not have enough juice to work it all. Do the lights dim when you try to start it, if so It's probably the battery.
Old Oct 1, 2007 | 03:02 PM
soulja's Avatar
no the lights doesn't dim, but someone said it is the starter ,but the atv is brand spanking new. It doesn't even sound like it want to crank, just a clicking sound from the electric start button to the solnoid- anymore tips help is still needed!!!!!
Old Oct 1, 2007 | 04:56 PM
xtc's Avatar
xtc
Put a screwdriver across both terminals of the starter selonoid with the key on,if it cranks,the solenoid is bad...just had to replace my sons on his kazumma..did the same thing
Old Oct 1, 2007 | 07:04 PM
soulja's Avatar
the place where i got it from said to do that ,but it still didn't crank then he said that it was the starter!! I didn't even ride it hard. The second day it wouldn't even crank. When i first drove it i didn't charge the battery up all the way!- anymore tips?
Old Oct 2, 2007 | 01:02 AM
outofline's Avatar
Have you tried rolling the quad while starting it with it in 1st gear?
Old Oct 2, 2007 | 02:57 PM
soulja's Avatar
it is an automatic, how do you know when the starter is bad?
Old Oct 2, 2007 | 08:10 PM
xtc's Avatar
xtc
Have you checked the battery with a volt meter?
Also,have you tryed to recharge the battery yet?
I can't tell you the exact way to test a starter but check the voltage in to the starter and make sure you have voltage in and out.
I can tell you how to read the meter if you need help with that.
Also,is there any safety swithes on the quad? if so,check continuity with the meter through those switches as well
Old Oct 3, 2007 | 08:07 AM
soulja's Avatar
I charge the battery up all the way yesterday and tried to crank it, the lights dim a little when i did this. It still didn't start. Someone elese told me that it proberly is a safety switch, how could i tell? could it still crank without the alarm?
Old Oct 3, 2007 | 09:14 AM
xtc's Avatar
xtc
Not sure on what the alarm function you are refering to does.
Do you still hear the clicking sound when you try to start it?
My best guess is that you either have a bad battery,which is not holding a sufficient charge or possible a blown in-line fuse somewhere in the electrical circuit.
If you have a meter,check the battery voltage.
if you don't have one you can take the battery in a local auto repair shop or someplace that sells auto parts and have it checked.
With the dimming lights, i'll bet the battery is no good,is the removable caps on top of the battery? if so,check to make sure the battery is filled up to the fill line with distilled water.
