HELP IS NEEDED!! PLEASE HELP!
Old Oct 3, 2007 | 09:21 AM
xtc's Avatar
xtc
Default HELP IS NEEDED!! PLEASE HELP!
I just remembered something,did you get the quad delivered to your house or did you get at the dealer already assembled?
When they ship quads,they usually don't send the battery filled with distilled water,my sons kazuma battery shipped dry( to prevent leakage in shipping) and came with a seperate plastic container filled with distilled water we had to add.
If you find the battery is dry,remember to add only DISTILLED water,regular tap water has too many minerals and will shorten the battery life greatly.
Old Oct 3, 2007 | 01:21 PM
soulja's Avatar
the alarm function is for shut-off and it has a small fuse, that runs to the wires. Do you know where the saftey switch is on the atv?
Old Mar 10, 2008 | 01:12 AM
jefflaverty's Avatar
try hitting the unlock button on the alarm.
Old Mar 10, 2008 | 04:59 PM
oneOone's Avatar
you can test the starter by taking a peice of wire and touching the starter hot(only wire on starter) to the positive on the battery. only touch monentarily it will either crank or not. by doing this you are by passing all other systems on the bike and only testing the starter. if the starter cranks then work backwards. mostlikly it is the starter switch(on handle bar) not making contact. the wiring connections on these bikes are not the best (had to build mine up with some soder)
Sjrpp
Jul 5, 2015 09:04 PM
traumajunkie
Jul 5, 2015 03:03 PM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
