FALCON 250 CARB FLOAT BOWL GASKET
Do you have teh old one? You can use a small amount of rtv if you cant fine one. Just apply a small coat to teh bowl and install bowl to carb. Let dry for a day and you should be good. Also if you had the old one you could trace it onto a peice of hard stock paper and cut it out with an exacto knife.
