Just Bought 2 From Raceway
Old Jan 12, 2008 | 11:37 AM
  #21
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Default Just Bought 2 From Raceway
<div class="FTQUOTE"><begin quote>Originally posted by: dbrown18
windtrader I slimed my tire mainly for flat prevention. I also thought it would help with the tire loosing pressure but it has not. I run about 4 lb of pressure and just have gotten into the habbit of putting air in when we head out for a ride.
bakermon thanks for the link to oregonvintage.com great info</end quote></div>
ATV tires need to be inflated to the "seating pressure" on the tire. Usually between 25 and 35 psi. I leave them inflated that high over nite and it helps let the tire set on the rim.
Old Jan 12, 2008 | 10:12 PM
  #22
dbrown18's Avatar
I did inflate them to 30 psi a few times back in may 07 when I first received the quads. The first time did not seem to help, the second time after I slimed the tires it helped but after a few weeks of no use there are always some (most) tires down around 1 psi.
Old Jan 14, 2008 | 05:52 PM
  #23
KTM Patrol
Former Chinese POW!
Bummer.....hmmmm... have you ever checked the valve stems. I have 2 tires that dont hold air well and the valve stem is the problem. Sure wish I could figure out how to change a valve stem without removing the tire.
COFatboy
May 2, 2020 12:06 AM
Jordanl6112
Aug 3, 2015 10:19 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
carolinabomb
Jul 26, 2015 08:40 AM
