New Utility 100 Won't Start
Old Dec 22, 2007 | 01:41 PM
kbizzo's Avatar
Default New Utility 100 Won't Start
We recently received our new ATV from Raceway and put it together (no assembly instructions were included), but we had it working. It ran for 5 minutes and then died. We tried charging the battery with no success. We found we had a loose terminal connection and fixed that, but still can't get it to run. When I turn the key, there is no noise at all, lights won't come on, etc.
Please help us if you have any advice - we have a son that will be sad his new Christmas present isn't working in a few days if we can't figure it out.
Old Dec 22, 2007 | 04:56 PM
89stp's Avatar
Have you check all the safety switches. Does it have remote kill, like a remote for a car alarm, if so make sure that one is not stuck or something.
Old Dec 22, 2007 | 07:29 PM
outofline's Avatar
It could be any of the following:
Bad battery (I doubt it could be that bad but a possibility)
Bad Fuse by the battery (if one is supplied in the wiring)
Wiring connection (doubt full as you already had it running)
Try Jumping it from another battery or a charger with a Starting mode, if you get life (lights anything electrical means it's your battery) I have seen batteries just completely die and the Chinese batteries are not too great!
Old Dec 22, 2007 | 09:31 PM
RacewayATV's Avatar
kbizzo:
our guys are answering emails all weekend for anyone that has any kind of problems and will be in on Monday for a 1/2 of day! Please call then or email us at
atvsupport@aol.com and someone will contact you!
John
Old Dec 24, 2007 | 04:05 PM
kbizzo's Avatar
I found that we had a loose fuse in the back, so we adjusted it and now the lights work. I bought an OHM meter and it showed that the battery had a full charge and it did not diminish when I turned the key to on and tried to start it. I have checked all of the kill switches and they are all disengaged. Still nothing when I push the starter button.
Where can I take this in for service in the Phoenix area?
Old Dec 24, 2007 | 04:06 PM
kbizzo's Avatar
Tried that. Still nothing.
Old Dec 24, 2007 | 04:07 PM
kbizzo's Avatar
Good battery. I checked all fuses and one was loose. It fixed my light issues, but I still can't get it to crank.
kbizzo's Avatar
Old Dec 24, 2007 | 06:31 PM
outofline's Avatar
An OHM meter will not tell if a battery is good nor will a Volt meter. Just jump the quad with another battery like a car and it will start!
Old Dec 24, 2007 | 09:37 PM
RacewayATV's Avatar
Send an email to atvsupport@aol.com with a contact number and I will get one of the guys to give you a call to try and help you out.
