No Spark on Kazuma Dingo 150
Old Apr 24, 2008 | 07:43 AM
mabrown9's Avatar
Default No Spark on Kazuma Dingo 150
I am not getting a spark on my son's kazuma Dingo 150. He ran it up a tree and flipped it over. Since then no spark. I do not have power at the coil. Does anyone have a wiring diagram or ideas for tracing the coil supply power back to?
Does it have a resettable shock/roll over sensor?
PS - The tree won the battle!
Old Apr 24, 2008 | 11:29 AM
chineseatvmechanic's Avatar
my bet would be only a wire came loose, dingos and most chinese quads are known for loose wire connections, and any little jolt will disconnect the connections, two places i'd start looking, the first place i'd look is at the cdi, make sure all wires are push in at each and every connector, then the two wires that go to the rear brake handlebar housing, if one of these 2 wires were knock off, it wouldn't start eaither
Old Apr 24, 2008 | 01:28 PM
spikedog's Avatar
I had the same problem with Coolsport atv it was the kill switch
we had hit a tree and on this atv it has a spring loaded kill switch
which works left to right
But when it hit the tree the riders hand pushed the button in and it locked in keeping the power from flowing
Old Apr 27, 2008 | 09:02 AM
mabrown9's Avatar
Thankyou. I found the red wire on the module just loose enogh as to not connect and not give me a spark. It is now running.
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
