Baby Falcon 110 will not start
Old Jun 7, 2008 | 12:34 PM
nattyb00t's Avatar
Default Baby Falcon 110 will not start
I have a Kazuma 110 baby falcon. I have had it for 2 years with little to no problems. It will not start any more. It turns over fine, has good spark. I checked the intake tube for cracks so there is no air leak and it is getting gas just fine. It also has good compression. I have seen some mention that I need to check the valve clearances. I saw some instructions for a Meerkat 50 but they do not totally apply to the 110. Can any one provide some detailed instructions on how to do that. Also any other suggestions on what to look at would be greatly appreciated. Thanks.
Old Jun 8, 2008 | 09:03 PM
89stp's Avatar
ARe you getting fuel? Is the plug wet?
Old Jun 9, 2008 | 08:27 AM
nattyb00t's Avatar
Yes I and getting fuel. The plug is wet and when I pull plug and check spark It has good spark.
Old Jun 10, 2008 | 01:35 PM
luvmysxs's Avatar
you should adjust the valves the same way as the meerkat. sounds like this is the problem especially if the valves have never been adjusted
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
big_g_squared
Jun 28, 2015 04:17 PM
1000gade
May 27, 2015 12:37 PM
Lasher
Sep 10, 2000 06:00 AM
