150cc HI-BIRD CARB
Old Jun 26, 2009 | 10:20 PM
mchsmth's Avatar
Default 150cc HI-BIRD CARB
This looks like a great resource, I wasnt able to find anything specific to my problem searching through the forums so I thought I would start a new thread.
I bought a 150cc HI-BIRD for my kids (got a really good deal) after a couple years its started to run really rough so I took the carb off for a cleaning, well I couldnt get several of the screws off (stripped them out) so I decided to buy another one instead of messing around with it. After a couple of weeks I re-installed the new CARB but I cant find the PIC I took of how the AIR/FUEL lines hook up. Can someone send me a PIC or 2 of how the AIR and FUEL lines hook up...I'm sure once I see it I'll remember!
Thanks, Mike
Old Jun 27, 2009 | 09:57 PM
mchsmth's Avatar
Well, I thnk I have the new carb installed correctly but I'm having the same issue as with the old carb, gas is pooring in to the carb, flooding it and pooring out of the over flow...it will flow in to the crank case if I dont turn it off. I dont crank the engine at all, the gas just lows right threw...does anyone have any idea what I'm missing?
I could still use a PIC of the air/fuel lines to verify I hooked them up correctly.
You can email me at mchsmth@broadstripe.net
Thanks, Mike
Old Jun 27, 2009 | 10:09 PM
split196's Avatar
gas pouring out..???? you wanna check the floats in the bottom of the carb....these sound like they are sticking open.......just imagine the bottom of the carb as a toilets water tank....when its empty the float is low and the tank fills to a preset point...the carb is stuck and thinking it needs to continue to fill hence why its pouring out of the over flow.....take a screwdriver handle and firmly 'tap' the bottom of the carb to replease the floats....i say 'tap' and not whack as you can crack the carb housing if to hard
hope this helps
Old Jun 27, 2009 | 10:12 PM
split196's Avatar
also the fuel intake for the carb will be usally up near the neck end where the air filter is....rest are proberly breather pipes
hope this helps
Old Jun 27, 2009 | 10:56 PM
outofline's Avatar
There may have been descant glel in the carb bowl that will dissolve after time but has a tendency to stick the needle. Drain the carb and bounce the rear of the atv up and down quickly may also help to unstuck it. If no luck then remove the bowl and see why it's sticking and or adjust the float!
Old Jun 28, 2009 | 08:40 AM
Seth 03's Avatar
my 150 jetmoto did this when I first got it.a small metal shaving was holding the main jet open(would'nt let it seat). after cleaning it out 3 times it works great. Seth 03
Old Jun 28, 2009 | 02:28 PM
mchsmth's Avatar
Thanks to all that replied...I stopped at TSC this afternoon and found and little dune/dirt buggy with the same engine/carb. The fuel intake line and over flow were mixed up, once I switched them around and capped off the overflow everything seems to be working normally.
Mike
Old Jun 28, 2009 | 04:54 PM
split196's Avatar
Wink
sweet....glad you got it sorted out
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
