125CC w/reverse and auto trans
Old Dec 16, 2014 | 05:04 PM
ShowMeGuy78's Avatar
Default 125CC w/reverse and auto trans
I picked up a new little youth 125cc. Planning to give it to the boys on xmas and trying to work out kinks before. I did make note that there was mention it was more for flat land. I tested it out on a little hill and did notice it has a hard time to start going if stopped on a hill.
Has anyone came up with a good fix for that? I was thinking of trying a larger sprocket on the rear but figured i'd ask here.
Other than this, I've been pretty happy with it so far. I did clean out the carb and change the oil as soon as I got it just to have a good basis if something was to give trouble.
ShowMeGuy
Old Dec 17, 2014 | 05:22 AM
brumbear's Avatar
They have an adjustment on the clutch side for a little slip it helps a little. There is a nut locking a threaded rod coming out of the side with a flat head screw driver slit cut in it try cracking that loose backing off a quater turn on the screw and lock it again this may help. If not look into a sproket change if it has a front sproket with 14 teeth put a 13 on it they are like $15.00
Old Dec 17, 2014 | 05:13 PM
I will take the cover off and see what it came with and decide from there. Thx.
ultangler
Nov 30, 2024 01:35 AM
akguy31
Aug 31, 2019 04:34 AM
Clint Russell
Sep 25, 2015 03:20 PM
Alex G.
Sep 19, 2015 06:34 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
