remote on 110 eagle atv wont work no power anywhere.
Old May 16, 2015 | 04:38 PM
jlafleur02's Avatar
Default remote on 110 eagle atv wont work no power anywhere.
I bought a atv was told its an eagle. I had to buy a battery connected 3 red wires to positive and 2 black wires to negative. No power anywhere and the remote kill switch button does do anything. The little red light comes on so I knoe its sending. I crossed out the soliniod and the starter turned so battery is good. The kill lanyard seemed to not click so I cut wires and connected them. Still nothing no turn over or even Lights
Any help would be great maybe I connected the wires wrong
Old May 17, 2015 | 08:50 AM
Zrock's Avatar
Super Quad Patrol
The kill switches sometimes work 2 ways. open or closed. try disconnecting the wires to kill switch instead of tying them together. Also follow your red wires and look for a fusable link or inline fuse, as well follow your black and make sure they are grounding. Could also be your handle bar switches that re not working as well or the key if it has one. I had a handle bar switch that would hang up on me. Had to listen closely and make sure it would click when using it
You could pull the black/white wire from your cdi harness this controls the kill switches and will eliminate that as a issue
ripperray
Oct 10, 2023 02:42 AM
3quadbob
Sep 18, 2016 09:46 PM
txkevin
Sep 21, 2015 02:02 PM
toonces
Jun 30, 2015 11:19 AM
brinkkl2000
Jun 11, 2015 12:46 PM
