Chinese atv electrical nightmare
Old Apr 17, 2016 | 04:39 PM
Jermfactor's Avatar
Use an on/off toggle switch to replace the key ignition.
Old Apr 17, 2016 | 05:58 PM
mbushue2's Avatar
Do you just wire the switch to starter wire? What do you do with the keyswitch plug? Wouldnt you need a keyswitch to shut atv off
Old Apr 17, 2016 | 06:05 PM
Jermfactor's Avatar
I still use the push button start just replace key switch with toggle to turn ignition power on and off
Old Apr 17, 2016 | 06:09 PM
mbushue2's Avatar
Guess i am to electrical handicapp to understand wiring one up. To many wires going to to many components
Old Apr 17, 2016 | 06:37 PM
  #15
Jermfactor's Avatar
All the key switch does is supply 12 volts to the starter button, ignition coil, and accessories (lights). Hence so many wires. They can be spliced together to the output of the toggle switch. i.e. 12 volt power in to one side of toggle the other wired accessories on the output. So when you power on the toggle you can use the lights, starter button now cranks the starter, and there is power in to the ignition. When you flip it off its like turning the key off basically kills the bike.
Old Apr 17, 2016 | 09:10 PM
  #16
mbushue2's Avatar
But would that supply power to start all the time?
Old Apr 17, 2016 | 09:27 PM
  #17
Jermfactor's Avatar
Only when switch is on.
Old Apr 17, 2016 | 09:41 PM
  #18
mbushue2's Avatar
So if you killed the switch to turn on the starter then it would kill your spark
Old Apr 17, 2016 | 09:42 PM
  #19
Jermfactor's Avatar
Would kill everything just like the key would.
Old Apr 17, 2016 | 09:44 PM
  #20
mbushue2's Avatar
Yeah but if you have 3 pole ignition button or switch. Ground, 12v power, and 12v output and you wire everything to output you would be running the starter the whole time other than to just start the quad
