Chinese atv electrical nightmare
Old Apr 17, 2016 | 09:45 PM
  #21
mbushue2's Avatar
Turning switch off the turn starter off would kill spark to keel running
Old Apr 17, 2016 | 09:49 PM
  #22
Jermfactor's Avatar
The push button start is what would engage the starter motor. The toggle switch is only supplying power to the push button. Only when the push button is pressed does it complete the circuit to engage the starter.
Old Apr 17, 2016 | 09:53 PM
  #23
Jermfactor's Avatar
Crude diagram...
Attached Thumbnails Chinese atv electrical nightmare-capture-_2016-04-17-21-52-40.png
Old Apr 17, 2016 | 09:59 PM
  #24
mbushue2's Avatar
Gotcha. Wasnt thinking that you use both toggle and push button. Would a remote control kill work with this setup?
Old Apr 17, 2016 | 10:02 PM
  #25
Jermfactor's Avatar
Should work fine. You are just substituting a on/off switch for the key switch.
Old Apr 20, 2016 | 07:04 AM
  #26
mbushue2's Avatar
So after 2 days. And new keys switch. Im no closer to an answer as to why it cranks with keyswitch. Even with push button unplugged it will crank
Old Apr 20, 2016 | 07:06 AM
  #27
mbushue2's Avatar
Sorry it will crank with brake switch and keyseitch on.
Old Apr 20, 2016 | 11:45 PM
  #28
mbushue2's Avatar
Fianlly got it to crank with button now. But have no spark. I ran through a pinpoint test through the cdi mr. Lynn edwards walked through with another known problem. All passed pinpoint. So i checcked DC volts from red/black wire coming from magneto. The AC ignition to ground pin. Hit start button and voltmeter reads -OL. Which im assuming my magneto is bad?
Old Apr 20, 2016 | 11:48 PM
  #29
mbushue2's Avatar
Also timing trigger wire from magneto reads .02 when cranking
Poorboy04
1) Engine problems..
Apr 14, 2016 08:05 PM
LostKeyboard
Apr 10, 2016 10:24 AM
gentlejax
Mar 25, 2016 07:52 AM
